Slasher:
I bought a Rostra a few months ago but ran out of time to install it. I did add a "bellcrank" to the end of ther carb "disc" when I had the carbs off when I replaced the needles & seats, so I am all set to go as far as attaching the control cable. Where did you guys locate the control unit ? I was thinking of mounting mine up forward in the plastic to keep it away from the engine heat.
What did you use for the speed input ? I was going to tap into the ignition pulser. Did you use the DC tach voltage as any input ?
I'm sure the cruise will make a big difference when cruising. Now I have to almost constantly keep my eye on the speedo because with wearing earplugs, the speed can creep-up to 85 mph too darn easy.
