Have used nothing but gallon jugs of Rotella T (now T6) 5W-40 in bikes for years, and from day one with the ST1100 when I bought it with 14,000 miles.
Last oil change I used what I thought was the same great Rotella T6 5W-40, but in a newly designed container. Same specs, different package. This was different than the prior T6 gallon jug. Bike now has 55,000 miles and shortly after the oil change I noticed the clutch slipping at times. This seemed to occur if I was cruising along in 5th, then dropped it down 2 clicks to 3rd for a pass. RPM's shot up as clutch slipped, and I would burp the gas, then RPM's would drop as clutch fully engaged. Thought it was an isolated incident, but it happens a lot. 2000 miles later, and I am going to try another brand of oil, probably Mobile1 Racing 4T. (EDIT) Now that I recall after looking at my old jugs, the prior T6 different jug design also caused similar slipping, but not nearly as bad. Two other old jugs used prior just showed Rotella T, not T6, and never any issues.
Anyone else have issues with latest Rotella?
Or, is it just time for clutch pack, but that seems too soon to me.
EDIT May 5, 2011:
Changed oil to mobil1 racing 4t.
Same thing, perhaps a little worse. Probably clutch springs as following posts suggest.
At least I now know that I can safely go back to my preferred oil of choice, Rotella T6 5W-40 full synthetic.
EDIT May 27, 2011:
Clutch springs did not cure issue. Suspect there is something going on with newer oil that meets new standards for cat converters that now come on some bikes, and might need to switch to oil with MA2 rating to prevent clutch slipping on some bikes. Just speculating on cause and cure. MA2 was created for the reason to counter drawbacks of newer oil causing more slippage.
EDIT May 5, 2011:
EDIT May 27, 2011:
