My first rebuilt water pump
I wish Hond would just make more water pumps. I can buy the water pump for my 1975 goldwing today by the dozen brand new from honda. Don't understand why they don't show the ST some love!
Wp arrived from fleabay with no connection for oil cooler ( later model pump ) . Cut the pulley and impeller off the "new" pump , makes it so much easier to support the casting when pressing out the old shaft/bearing, and pressing in the new one. Pressed off the pulley and impeller from the pump I cracked in the press ( I was really being careful too ! ) used them to finish the wp refurb. The missing oil cooler connection was retrofitted by drilling through the existing blind hole in the casting, smoothing off the newly opened port on the impeller side with a pencil die grinder, and finally tapping the hole M8x1.5 pitch about 10 mm (3/8") deep before screwing in a brass hose tail ( from an old auto wp) with copper sealing washer. See attached photos of rebuilt wp and oil cooler mod. Just the heads to refurb now........hopefully up and running soon !IMG_2868.JPGIMG_2869.JPG
Hello Jim,
Can the AISIN WPH-002 water pump for Honda Civic be useful ?
Can the automotive Seal from the donor pump be reused ?
Can you explain your method for wedging the aluminum part of the water pump so that it does not crack?
Thanks Jim.
Hello Jim,
Thanks Jim.
rebuid kits are available on ebay, to rebuild watch
