without a doubtAt least *some* of that crud is likely from the paint on the radiator itself.
Tank is still reasonably white.Is your tank still white, or is it yellow or orange from too much heat?
You may want to consider cleaning your idle wax valve assembly too.
Since it appears your going to have reset one valve cover anyways....
I would recommend using the valve clearance worksheet![]()
Fortunately that’s the old impeller, bearings and seals that need replacing anyway. I want to get the aluminum clean. Good info for future though. Thanks!Evapo-rust is good for cleaning off rust, however, the moment your rinse it off with water, it will flash rust before your eyes, if you don’t treat the surface with oil!
Do you want to put oil in your coolant system?
I’d be more concerned about the rust on your bearing/oil seal spring-ring/and mechanical seal now.
Some of these service jobs cannot be sat down and walked away from as you are finding out, and must be completed from start to finish to prevent stuff like this from happening.
