To clear up some of the muddy waters....Larry didn't spend $1,400 dollars for a final drive, this was a price of a new part from Honda. The pumpkin was replaced because the male splines, as well as the female splines were toast, and I didn't have the tools to rebuild the rear driveshaft assembly, and measure all the gears and stuff. The owner did find a used one on ebay that a local shop was parting out that happened to be his year, a mated set, and very low mileage unit with no damage.
The so called smear test, was a conversation between John and I talking about the different colors of Moly 60 from Honda Moly 60 tubes.
As far as the term assembly lube, I agree, most assembly lubes are designed to wash away with oil leaving no deposits behind, However, I have been using the Bel-Ray stuff for the last 10 years or so, on my personal bike, and have had very good results, no wear, and always find it still in place 10,000 miles later when I go to change the rear tire. This is what Bel Ray recommended for use on DRIVESHAFT SPLINES, as well as U-Joints, and other very heavy duty operations back when I started using it.
My original container did not have the words assembly lube on the bottle. The spec sheet they emailed me years ago indicated that it had 42-45% moly solids in it. (this may have changed) but I have a couple bottles of it, and have enough to last a lifetime.
Now, to muddy up the water even more....I recently talked to a couple upper end service folks at very reputable dealerships, who work on the ST1300's alot, and the question of "could Honda have received the wrong paste, in the normal tubes" etc.
This was asked because of the color difference etc. It was suggested that perhaps someone "may have done that" and then when they figured out there was a problem, they pulled all the Honda products, and scrambled to sell something else (M77).
This is all speculation....but after talking to John, and seeing the difference in colors between his Honda Moly 60 tube, my Honda Moly 60 tube, and my older Honda Moly 60 tube, we found we had THREE different colors...
Just made me question this even more....
The dealership had just mounted a fresh set of OEM tires on his bike, and claimed that the splines were perfect, and that they used the approved Honda M77 paste/grease as directed.
