Is the classic sport-touring motorcycle doomed to extinction?
I don't mind lubing a chain, but depeending on the chain and bike, frequently adjusting the chain can be a "chore,"
I came up with my own chain-adjustment method that minimizes slack, which should help maximize mileage, while avoiding over-tightening:
The factory recommends 3/4 to 1-1/2 inches of slack with the bike on the side-stand, but how accurate is that? The ideal slack is as little slack as possible without ever getting too tight, so I use my own procedure. I start by lubing it after a warm-up ride, then let it cool, maybe overnight, and on the center stand.
I remove the seat and route a tie-down strap over the bike frame, under the swing-arm on both sides, back over the bike frame, and hook the strap ends together. I then tighten the strap, compressing the rear springs, until the sprockets are in a straight line with the swing-arm pivot, which is where the chain will be tightest.
I then rotate the rear wheel several times while checking the chain for the least slack, as chains don't usually wear evenly. Once I find the position with the least slack, I adjust the chain for very little play, maybe 1/2 to 3/4 inch. That's as tight as it can be without the risk of it being too tight. Throttle response is crisp, too.
From the NH Forum, more detail. There were a couple of comments or questions which I omitted, which is why some of my comments appear to be responses:
And from another thread, which became more of a discussion:
Let me see if I can explain better: We agree that the chain, sprockets, and even bearings will suffer extreme wear and possible damage with the chain too tight. The following presumes that we have lubed the chain and found the tightest point in its rotation:
A chain connecting two fixed-in-place sprockets can be tightened well without damage, because the distance between them doesn't change during operation. The chain on a bike must cope with varying distances, because the swing-arm pivot is closer to the rear axle.
As the rear suspension moves, the rear sprocket moves in an arc. The two sprockets are the farthest apart when the two sprockets and the swing-arm pivot are in a straight line. No matter what movement happens, the sprockets will never be farther apart than that.
The 3/4" of slack spec is with the bike on the side stand, when the swing-arm pivot is nowhere near being in a straight line with the sprockets, which makes it an approximation at best. What happens on a bike with worn or different-than-stock length springs?
What I do is pull them into that straight line with a ratchet strap. I take the seat off, run the strap over the frame, under swing-arm on both sides, back over frame and hook the ends together. Then I tighten the strap until the straight line has been achieved.
Now, no matter how the suspension moves in operation, whether from load weight or aggressive riding, the chain will never be pulled tighter than it is at this point. If I adjust for minimal slack now, the tightest the chain will ever be in use is how tight I make it now.
If your point is, even knowing what I'm saying above is physically correct, that my 1/4" of slack is too little for a chain with fixed-distance sprockets, then that is a separate debate. I will do some research and report back with my findings. Until then . . .
Purposely avoiding motorcycle and bicycle sites, here's the first thing I found:
https://www.cisco-eagle.com/service...maintenance/conveyor-maintenance/belt-tension
And yes, as the chain wears, the pin-to-pin distance increases, which allows the rollers to ride higher on the sprocket teeth, which in turn increases chain wear, and the effect snowballs. That's why old sprockets cause new chains to wear faster.
I didn't read about doing this anywhere; it just came to me while thinking about it. I believe the tighter the chain, without being tight enough to increase friction or squeeze out the lubricant, the better. There's no advantage to the loose side flopping around.
An extremely-too-tight chain could even stop the suspension from compressing. Here's just about everything you could ever want to know about chains. There's even a motorcycle chain section in the index:
http://tsubaki.ca/pdf/library/the_Complete_guide_to_chain.pdf
On my '96, as well as my old '82, the suspension must be compressed for that alignment. It's strange to me yours doesn't. I'll have to look for pics of Nighthawks without mufflers.
Various thoughts:
1. Perhaps you have shorter-than-stock shock/spring units, but I can't imagine all of the suspension travel is only above the straight line. That would be such a waste of available travel.
2. I would expect to find the straightest alignment with the bike nominally loaded and with the suspension correctly adjusted for that amount of load, not at either end of range of motion.
3. A center-to-center change of 1/4" would, of course, result in a change of much, much more than 1/4" of chain slack. A quarter turn of the adjuster bolts can go from too loose to too tight.
4. I've had a 16-tooth sprocket on hand for some time, waiting for either the existing Regina chain to wear enough to fit, or wear enough to be replaced with the waiting 112-link chain.
HP is saying that, if you start with the three points in a straight line, that slack can only increase. We all agree on that. What's different is that he believes that those points are in line with the swing-arm at it's lowest position, i.e., with the bike on the center stand.
You and I obviously agree that the straight line occurs only with weight on the bike, which is what I mimic when ratcheting the swing-arm upward. I also do this with the bike on the center stand, otherwise the bike could fall to the right, pushed by the kick stand.
I think designing a bike with the swing-arm straight with no weight on it would be to intentionally waste 50% of the available suspension travel. As I said in a previous post, I think the straight line only occurs when the bike is well loaded, like with a passenger.
If the sprockets are at maximum distance apart, and the chain at the tightest place, the chain will never be tighter. So, what's "too tight" about 1/4" of play?
Only because, as rarely as a chain adjustment is needed, I would have to make sure that the bike is sitting exactly the same every time.
Plus, how do you make sure the chain is at the tightest place with the rear wheel on the ground?
I have seen such a setup accomplished in two different ways:
1. A custom frame was made with the swing-arm pivot points outboard of, and in line with the counter-shaft (front sprocket).
2. A dual sprocket was mounted on the swing-arm pivot shaft, and there were separate front and rear chains. This was made to allow for an extra-wide rear wheel.
To add, yes, the chain slackens a bit with the suspension either compressed or extended from the center, straight-line position.
The question is: by how much, exactly? How do we know that every '91-'03 NH750 is sitting with the rear compressed the same amount every time it's parked?
I believe the side-stand recommendation is based at least partly on the fact that the center stand was not standard equipment.
And, there is the previously-mentioned variations in wear along the length of used chains, which either must be found or allowed for.
I believe the goal is to have as little slack as possible without ever getting tighter. What works better to obtain than my method?
I merely meant that no one number applies to every bike, so the recommended slack is an average-based compromise, and my method applies to my chain on my sprockets on my bike. I'm concerned only with my bike, as I'm not responsible for writing a user's manual for everyone else's bike.
As long as that too-tight point is avoided, the best mechanical efficiency in transferring energy is achieved with a snug chain. I do spin he rear wheel around a few times in both directions and check for a missed tight spot after adusting.
To me, my method firstly avoids the possibility of making the chain tight enough to risk any of the above caveats, and secondly, otherwise allows me to get it as snug as practicable while avoiding "firstly."
http://chain-guide.com/basics/7-1-2-1-chain-slack.html
http://chain-guide.com/basics/2-1-2-engagement-with-sprockets.html
Additional food for thought:
I imagine that a bike's suspension (or any vehicle, really) would be designed so that, during normal load and usage, there is much more compression travel available than extension travel.
I have new Hagon shocks with springs selected by Dave Quinn (ret.) after discussing my weight, the full luggage system I added, tools and such I normally carry, and allowance for a passenger.
Combining the two lends me to believe I'll never ride an appreciable distance (if any) with the suspension compressed to the point of minimum chain slack.
The way I do it, there are no measurements and, right or wrong, the chain ends up being as snug as it can be while still assuring no chance of binding.
Great idea! Something I can try when alone in the garage. I've occasionally resorted to having someone heavier than I am sit on the bike while it's on it's stand to do just that.
Most of my bikes (performance) are suspended on the stiffer side. And getting to the subframe rail requires more than removing the seat. In some cases, the tailsection would have to be removed to do that. I will typically tighten the chain to the tighter end of the recommended slack (at the tightest point of the chain) and have found that it's just about right. I suspect that the hard acceleration and engine braking wear the chain/sprockets faster as well as the typical 520 conversion. But I do have a couple of more gentle rides that I can give your method a try. Thank you!
That might depend on your policy, annual miles ridden, and claims data for the Ninja 1000. For example, the cost of liability insurance for my ST1100 is almost half of what it costs for full coverage on one of my similar displacement Ducati's that makes close to 2.5 times the horsepower and costs over 40x that of the ST to replace. I suspect that for me, it would be somewhere in between for the Ninja 1000 for full coverage. YMMV
?Hmmm? Having owned a Ducati or 2 something doesn't sound right. Let's say your ST1100 is worth $2500. Multiply that by 40 and you're at $100,000. Yes there are expensive Ducatis but most are in the $30,000-$40,000 range.
Traditionally Ninja 1000 are expensive to insure. I think mostly because of the name and 1000cc. Insurance companies lump it in with 1000cc sport bikes.
A lot of times older bikes without ABS are comparatively higher to insure than newer bikes with ABS.
Out curiosity, did you ever adjust the chain using the factory procedure and then compare that to how much slack you have measuring it using your procedure. I would be curious to know how they compare.
i.e. Adjust it to the minimum 3/4" specification using the factory procedure and then use your procedure to measure the slack. How close to the 1/2" to 3/4" that you want using your procedure is it? Is there a possibility that it comes so close to the same thing that it is easier to use the factory procedure setting it to the minimum end of the specification?
Maybe I should have said 16x? ;)
I try to keep specifics under the radar for personal reasons, but yes, it's $100k.
2021 Ducati Superleggera V4 -- (only pic on my computer) this particular one belonged to Ducati who was nice enough to let us ride it at Misano World Circuit Marco Simoncelli as a warm-up to riding Michael Rinaldi's factory World Superbike and Michele Pirro's factory MotoGP bike.
I don't ride mine often, less, than 500 miles annually, hence the very affordable insurance. I currently ride the ST a lot more, but still not that many miles. Still baffled by the insurance price delta.
About 370 lbs with a couple of gallons of gas, 235-ish hp currently. As you probably know, Superleggera means Superlight, which is why I call my beloved ST: Superpesante (Superheavy) ;)
p.s. I have the previous version SL as well which is a 1299cc twin, and it costs a little less to insure than the V4 version above. I just sent a 2004 Ninja ZX-10R (way more mental than the Ninja 1000SX) up to my son in WA for track use, but I was quoted even lower than the twin if I wanted to put it back on the road.
No; while I don't claim it's the best way, I see no advantage to doing it any other way.
For example, how do you locate the least slack with the rear wheel on the ground?
If I lubed the chain after the warm-up ride, the bike will already be on the center stand.
This job is necessary so relatively rarely, it's really not a hassle to do it the way I do it.
