I've seen Harley Chicks a lot heavier than that dirt bike on the back seat.
OK Larry, Good point...The sticker on the rear rack on the bike states not to load beyond 10 lbs. How much does the topbox weigh?
I had several BMW F-650 single's (Retired from service loaner bikes) and when the small BMW top case was installed on ANY of them, it would change the handling enough to notice by making the front end light and twitchy, and hunt around on the highway, and this was when the cases were completely empty.
I ride my '02 ST1300A in/around Merseyside. Officers that served with him are always happy to stop & have a chat.After the release of the Coroners Report in April 2007 blaming the ST1300 for the death of PC David Reeves, a Merseyside motor officer, the ST1300
I only ride with the box on for trips, otherwise leave it off. I have never had any noticeable change in handling with the box on.
BUT - I don't (ever) ride 100 mph+. Doing that, box or no box, is just dumb, IMHO.
Just weighed mine. The top box weighs about 13 lbs.
Larry, that may be the weight recommendation when the st13 first came out in europe in 2002. Then we got the weave. However as someone pointed out earlier these top boxes were only available in europe therefore the warning label on the mounting plate may have predated the discovery of the pan weave.The mounting plate and top box are made by GIVI (as we all know) and not sold by Honda (as far as I know). While Honda issued a 10 lb recommendation, GIVI probably did not bother to change their label. My top box weighs around 14 lbs. Its the pan european. Another 10 lb would take it to 24-25 lbs or about 11 kg. Still in the park.I have the Honda top box, it's load max is 19.8lbs /9kg.
Since I have the Laminar Lip on my (stock) windshield I can ride, always, with the windshield all the way down. This gives a big difference in stability, over having it up.
Maybe that's why I don't feel any difference with the box on, I dunno.
And since the Lip directs the breeze up and over my head, I get no wind in my face with the shield down.
I wouldn't ride without it.
I also have the European box on my bike, and have been guilty of packing quite a bit of stuff in there, and have had no issues with handling either.Larry, that may be the weight recommendation when the st13 first came out in europe in 2002. Then we got the weave. However as someone pointed out earlier these top boxes were only available in europe therefore the warning label on the mounting plate may have predated the discovery of the pan weave.The mounting plate and top box are made by GIVI (as we all know) and not sold by Honda (as far as I know). While Honda issued a 10 lb recommendation, GIVI probably did not bother to change their label. My top box weighs around 14 lbs. Its the pan european. Another 10 lb would take it to 24-25 lbs or about 11 kg. Still in the park.
Yes Pan Weave is well documented, but weave existed since the very first motorcycle and in fact you rarely get high-speed weave without low speed wobble. Motorcycles with approved tyres in good condition run at correct pressures, at normal speeds and loaded within spec will rarely have issues with w and w.
You may be experiencing instability rather than true weave in those conditions. If you've ever had the frame start to hinge on you at high speed you'll know that weave is a lower intestine emptier rather than a "oooh that feels strange moment".Great Info. Thanks for posting. This should clear a lot of myths about the weave and the pan weave. I do experience weave when behind trucks.
Everything that was written on the UK wobble came back to one thing and that was the telescoping blue light mounted to the right rear crash bar. We have been operating Honda ST1300's in the states for years but are not required by law as the UK police are to have that telescoping bar. We have all of our radio equipment and electrical components mounted where the rear passenger sits. We have a shotgun/AR/ and baton mounted horizontally and balanced on the center shelf. We have never had a police officer involved accident in the states attributed to a speed wobble on the ST1300.This topic has been covered to death already, but to remain polite about it...
Yes, UK Police felt that the risk of high speed instability, and the health effects on their officers for the ST1300, were simply too great, so they were pulled from service (they now ride BMWs). There was an investigation, where one specific UK Police force worked closely with Honda engineers, a bunch of things were tried, but nothing that resulted in the ST13's remaining in service.
I can't comment on top box availability in the US, but my bike (in the UK) has one, and it is often loaded. Yes, it's away from the CG, yes it makes the bike handle differently (even when it's empty, vs it not being on the bike). But I've gone out of my way trying to find the limit of grip on my tyres, and trying to reproduce the same wobble that the P spec bikes saw.
It turns out, that I'm just as good at reproducing the problem, as Honda are at fixing it (I don't think I saw it, it's much more likely that what I saw was poor tyre pressures and/or a high windscreen while playing in the wake of a big truck).
Did you ever see that video of a group of TX LEOs riding weaving STs in unison down a Texas road? We should try and dig it up. I think there was one out of Japan that was similar.Everything that was written on the UK wobble came back to one thing and that was the telescoping blue light mounted to the right rear crash bar. We have been operating Honda ST1300's in the states for years but are not required by law as the UK police are to have that telescoping bar. We have all of our radio equipment and electrical components mounted where the rear passenger sits. We have a shotgun/AR/ and baton mounted horizontally and balanced on the center shelf. We have never had a police officer involved accident in the states attributed to a speed wobble on the ST1300.
Interesting. I would like to see how they had their bikes set up and what tires they are running. I will tell you, the stock tires that came on our ST1300's from the factory were horrible on California freeways. We have deep grooves cut into the cement and asphalt. The stock front tire design had those three lines that ran parallel with the freeway lines on the roadway. It made you feel like you were floating across the lane. We instantly changed the tires out and the problem was gone. The original tires were "run flats", which the factory stated you could run them without air and they were not suppose to come off the bead. The replacement tires were not run flats. We go annually to EVOC to use their pursuit course and we have maxed out the throttle for long periods of time and none of us have felt any weave or wobble. Of course this was all done in the interest of training of course.Did you ever see that video of a group of TX LEOs riding weaving STs in unison down a Texas road? We should try and dig it up. I think there was one out of Japan that was similar.
The weave, it's not a wobble, is real with many civilian STs but it's fairly benign in that it starts gently and only increases in magnitude as the rider continues into speeds up beyond 100-115 mph. It does not come on with a sudden onset and you have to be going pretty fast to experience it, fast enough to go to jail in many jurisdictions. It doesn't suddenly happen out of nowhere and throw the bike out of the rider's control. If the rider is so inclined to explore the weave when it occurs....... the bike can be ridden a little faster, held at that speed, then a little faster, held at that speed then a little faster and so on to see how the weave increases in magnitude with subsequent speed increases to 125+. Lying on the tank does nothing to reduce or eliminate the weave's magnitude. Only speed reduction reduces then eliminates it.
Or so they say. I wouldn't know
