Anything that affects both sides equally is in or before the signal switch.
Nah, they're just very well neglected items...The switch is the well known weak spot.
Not on my ST11.Anything that affects both sides equally is in or before the signal switch.
Explain, please.Not on my ST11.
I can't really, electrons are a mystery to me.Explain, please.![]()
Well, that doesn't contradict what I said:Just like the OP my indicatorS were troublesome and only a new switch fixed it.
The second half of my statement (not said before because the first half applies to the OP) is:Anything that affects both sides equally is in or before the signal switch.
looks like it was switch gave it good clean and squirt of wd40This was my experience as well- the switch plugs in a location that requires removal of the ‘false tank’ cover and you need to remove some parts to get to it (just aft of the steering head essentially)- it’s a bit of pain but quite doable- I replaced mine on the 2000 and all has been good since then. I never had to do this on the 94 which surprises me.
I've seen that on one of my ST1100s before - when it got really cold, it just didn't want to work properly.All sorted and thanks for all the help it was the switch I gave it a good clean and squirt of WD40 and its winking away well thanks again. It as been cold here so guess might have had something to do with it
How Pans have you gotI've seen that on one of my ST1100s before - when it got really cold, it just didn't want to work properly.
Glad you got it sorted!
Technically 8 ST1100s - 4 runners and 4 parts bikes.How Pans have you got
The opening story still doesn't make sense...I've seen that on one of my ST1100s before - when it got really cold, it just didn't want to work properly.
Unless there are hidden "dummy" load resistors intended for LEDs.If the switch doesn't close in either direction, the relay won't see any load, hence won't "click"...
Well, that's an information kept secret from us...Unless there are hidden "dummy" load resistors intended for LEDs.
Blimey they are great bikes bit heavy are you in UKTechnically 8 ST1100s - 4 runners and 4 parts bikes.
Over 1/2 million miles between the 4 runners.
I have ridden all 4 to 49 states (no bridge to Hawaii) and have pictures of each bike at each state line sign.
Uncle Phil - The Bikes
www.unclephil.us
Just seen your in statesBlimey they are great bikes bit heavy are you in UK
Just been reading your blogs and videos perhaps you should put them onnyou tubeBlimey they are great bikes bit heavy are you in UK
It's strange indeed. But it is definitely temperature dependent. When I thumb my turn signal, it won't actually start flashing for several seconds. But it will light up when I move it to the left or right...I can make it work manually. [NOTE: I see the dash indicator flash, can't confirm the signals are actually working too.] Not sure how that happens if the relay is the ONLY closed circuit path. But flicking the switch closes a contact and stays closed until you cancel it. That sends electricity through the relay primary.The opening story still doesn't make sense...
The t/signal relay is load depending (bi-metal)...
Its all sorted cleaned it and put some wd40 spray and its now working thanks anywayIt's strange indeed. But it is definitely temperature dependent. When I thumb my turn signal, it won't actually start flashing for several seconds. But it will light up when I move it to the left or right...I can make it work manually. [NOTE: I see the dash indicator flash, can't confirm the signals are actually working too.] Not sure how that happens if the relay is the ONLY closed circuit path. But flicking the switch closes a contact and stays closed until you cancel it. That sends electricity through the relay primary.
Once the juice flows in the circuit, I think the relay heats up just enough to soften the bi-metal and get it to click. I find the more I use it, the more responsive it becomes. I'm sure I have an electrical diagram somewhere, but I'm just supposing here.
Anyhoo, the short answer is, open it up, deox it, and lube it (not with grease). As evidenced, tangling with Honda wisdom is usually a futile effort.
This winter is the first time I've had this happen. Only to the right at this point.When I thumb my turn signal, it won't actually start flashing for several seconds.
