Progress Report
Day 1...
Sagging courses of brick pulled back and old 2x8 edge removed.
The bricks sit atop a bed of sand, which in turn is underlain by a concrete slab. The edge of the slab is crumbling in places.
It appears that the slab may have a shallow V in the upper surface, to channel water down and toward the center of the edge that's in trouble. That could explain a lot about why that edge moves; the depth of the sand is only a couple inches, which to me seems insufficient to explain why the edge moved so far so fast.
Here you can see the slab. It looks tobe 5 or 6 inches thick at the edge, maybe 4 inches at the low point of the V.
New timbers in place but not yet pinned with rebar. They sit on top of a couple inches of drainage stone that I laid in and tamped lightly.
Bottom course is 4x6 stood on edge. Top course is 4x4.
Next steps include pinning the timbers with rebar then backfilling both sides. Exterior will be the dirt I disturbed when trenching, interior will be sand.
Detail of the gap between the timbers and the existing sand.
It's level, and plumb (for the moment at least).
Next, I'll drill for the rebar and drive those pins, then backfill both sides. Finally, I'll add sand and re-lay the bricks. But that's a job for tomorrow.
