Pop-Pop
It looks like ill b doing the meet near taos this weekend. Ill take a peek. Many thanks!If you’re headed north it would be a mistake to miss the rio grande river bridge just west of Taos.
Discovered my ambers and low beams dont work, so i have a small emergency here. High beams work, so i suspect the fuse is fine and, hopefully, a easy fix at the shop.
The ambers were installed by your shop back in Boston, right?? Hope they didn't do something weird to your electrical system.Discovered my ambers and low beams dont work, so i have a small emergency here. High beams work, so i suspect the fuse is fine and, hopefully, a easy fix at the shop.
Going to a mechanic my kid uses here in pagosa. Gonna strip off some plastic myself to save $$ and speed up the process i really cant stand my bike with things that dont work. Especially safety things.If it is easy to do, I'd unplug the ambers and see if that fixes the low beam problem.
Yea, i tipped the guy!Glad it was an easy fix!
Did you camp at the Sonic Drive-in?
Ha! The sun was rising fast and i had to hurry the shot. My kids, who correct me often, said i should have cropped it. A nice sunrise, but one of my poorer shots. If i had to camp at a drive thru, it would def b burger king.Did you camp at the Sonic Drive-in?
Kept losing power and finally the bike quit on me. Of course, miles from cell or service
So, i took it all apart and replaced the gas filter with a tent pole repair tube (thanks joe!) and off i went. Bought two gas filters at napa and will be correcting things today.
My deepest thanks to the many riders that stopped to make sure i was ok.
So Mike, did the bike run fine after your fix? If not, I would suspect the fuel shutoff valve. There’s a very good Article on the bypass of the shutoff valve:
Article [11] - ST1100 - How to do an emergency bypass of the fuel valve | ST1100 Articles
The ST 1100 has a fuel valve that is operated by vacuum from the engine. This valve has been known to fail, and like most failures, it won't happen in your driveway - odds are that it will happen when you are a long way from home. The valve usually doesn't fail abruptly and bring you to a...www.st-owners.com
