No, replace.Hi,
Is this filter cleanable - wash and spray with K&N oil or just replace it?
It is (embossed PN is a giveaway) and I'd stick to it...I think it's OEM.
Not the case with the EMGOs that I have found (had them side by side).No, replace.
Found aftermarket filters having thinner paper -> less restrictive -> leaner mix...
Got a pattern delivered (instead of the OEM I'd ordered) by David Silver for the ST1100, ran weird and ended up with snow white plugs...Not the case with the EMGOs that I have found (had them side by side).![]()
Can't tell, they slap 17211-MT3-000P on, stuff it into a similar looking, white box as the OEM; only the plastic bag around the element is missing...Martin - Was it an EMGO or some other aftermarket?
I've had no trouble out of EMGOs.
Such does crack up the pores...Ten years later they would no longer do that because the claim was that it could cause enough damage to the filter rendering it non effective.
Actually, I agree here…my 2 STs might see 100K miles each, and I have no doubt they’ll make it at least that far with the current maintenance I perform. For my 2000, it has just past 50K miles and the 94 has 54K…I doubt either one will hit 200K, at least not in my lifetime (assuming I’m still riding 20 years from now). Ultimately, ‘good enough’ is likely fine for these bikes, since they have pretty low stressed engines vs a supercharged 14K RPM bike like the race bikes (like an H2 although I’m not use what that redlines at). Same with my cars…I use acceptable products (like Supertech synthetic oil, which has been rated as perfectly acceptable for the normally aspirated engines my cars have)- can those go to 300K miles? Maybe, maybe not, but again, likely not in my lifetime as I normally don’t drive that much.It is my understanding that paper media filters are disposable and anything you do to clean or reuse them damages the filter. These are designed to catch a certain % of particles of a given size - for example 95% of particles 0.5 micron and up. Trying various methods to clean the one time use filter will get you anecdotal evidence - one person's trial that might or might not be effective with no proof either way. Yes, we can all find cheaper filters, but absent an independent testing of it's effectiveness it is really guesswork as to how good it really is.
In the end, many of the aftermarket items are 'good enough'. We have one bike on this forum (that I know about) that has gone 400,000 miles. Realistically, we could expect more STs to go that far, but many will die in accidents along the way or sit in garages until they die. If the average mileage of STs at the point when they are scrapped is under 200k miles, it doesn't matter if the owners used paper filters, KnN filters, or any brand of oil or oil filter. Back in the day, how many bikes did we see with velocity stacks and no air filters on the carbs? Those bikes ran for maybe 50K miles before something else caused their failure. Today, we can get more than 4 times the life out of an engine but how many of us use all of it?
