- Joined
- Feb 11, 2006
- Messages
- 8,041
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2025 Miles
- 006335
I missed your use of the word Dynamic in the previous post. I'm not sure I understand how you use that measurement - or get it. If you want the travel to remain in the upper 33% of available distance while under way (dynamic sag??) I think you would have to have a much stiffer spring than the 900-1300 lbs we have been using in these suspension threads. That sounds like a punishing ride to me. The 25-33% Static sag number in theory allows the shock to work over it's entire range of travel when under way.I don't have my shop manual handy - it's at my other house. What is the total travel of the rear suspension per Honda? Doing some reverse math, if 30 mm = 25% of shock travel, and 40 mm = 33% of shock travel, then total travel should be 120 mm (4 3/4"). Did my college education serve me well?
I agree, dynamic sag should be on the order of 1/4 - 1/3 of total shock travel.
BTW, 1?" static sag would be way too soft a spring IMO.
The service manual gives rear travel as 123mm or 4.84".
