Any chance it could be the tps?Speed is relative.....40 mph, on a twisty road, on an old BSA 441 Victor Single, is terrifyingly fast
I would imagine it would set a TPS circuit code if that were the case, but I suppose it's possible to have a glitch that happens fast and the ECM does not flag it as a code, but the parts cannon approach here is only going to get you broke and even more frustrated. You could test the signal at the TPS via backprobing the signal circuit pin and using a graphing meter - set a fairly fast time base say around 1/2 sec per division or so, and with KOEO slowly move the throttle open to close and see if there are any drops or spikes ( the spikes you would see from a bad TPS would be signal circuit bias voltage, usually 5 volts, but the connected TPS pulls that voltage down. Thats how the ECM is able to fault sensors)Any chance it could be the tps?
ECM Fault CodesThe fi light isn’t flashing, but someone mentioned stored codes. How do you find those?
Is this the one since I already have a new filter?
Fuel Pump w/ Tank Seal for Honda Motorcycle - OEM Replacement, HFP-382-YT30 QFS
SUPERIOR PERFORMANCE, FREE SHIPPING from the AUTHORITY on OEM replacement Fuel Pumps. SAVE on parts designed specifically for your vehicle. Shop HFP-382-YT30www.highflowfuel.com
Doesn't mean that you get a constant flow at 50 PSI under stress.Got the fuel filter out. Fuel poured out of both ends freely and crystal clear
The fuel hoses that connect to the filter?While it may be ok to use the pump, DO NOT use the fuel hose that comes with it, I would only use OEM Honda gasket and fuel hoses.
Thank you I’ll look. All the hoses are in good shape though, it’s been garaged in Texas it’s whole lifeHi all.
I would like to add my 2 cents.
Sounds very much like clogged / ruptured T-piece. (Vacuum hoses underneath the air filter connection to 5-way joint).
If the they get stuffed, the vacuum is not registered correctly and you get weird stuf. Same if you have a leak in one of them.
Would suggest to take some time to check these thoroughly.
Regards,
Vince
