My 06 has the same problem. What is the part number for the sending unit?
Chris, they replaced my upper fuel tank sending unit and it solved my problem. They also replaced the fuel line between the upper and lower tank. I believe the manual says to replace it if removed. My bike was under warranty. I believe you are safe just ordering the part and doing the work yourself. It's up to you if you wish to change the fuel line as well. Probably a good idea though.
Well, local Honda dealer installed a warranty new upper fuel sensor unit. Took about 20 minutes and I was back on the road. Whether it fixes the 3 bars to blinking 1 bar problem and gives me the 2nd bar back remains to be seen.
Sensor coming out didn't look any different than the new one as far as angle of the wire arm or anything. Metal contacts looked a little worn but in good shape. Swapped out at 33,000 miles.
More to follow after I ride the tank down below 3 bars.
Shuey
Two half tanks put through and the 2nd bar is back. To early to declare a final victory I think, but in this one case at least it looks like replacing the upper fuel sensor solved the problem of the missing 2nd bar.
Shuey
Good for you, and I hope it continues to work correctly. So since it is not easy for me to leave the bike and get a ride home etc. it sounds like I could wait on it if I can get the dealer to get on it right away. That is not always an easy thing to do. Hmmm. Thanks for the info.
JDP
After the 2nd tank of gas did the same 3 bars to 1 bar flashing thing, this current tank was almost completely empty in the upper tank so I decided to pull the float and 'tweak' it a little to see if maybe I had possibly 'bent' the float arm while putting gas in. Being very gentle, I removed the float assy and it looked fine. There apparently is a delay with the computer to display the float movement because I could not make the dash bars change by manually raising the float. So I gently 'realigned' the float upwards. That is I bent the float arm so the float would ride a little higher in relation to the sweeper arm of the sensor. Being careful/gentle I reinserted the float into the tank making sure the gasket was where it should be so I should not have any fuel leaks after this next fill up. Turned on the key and bam... 2 bars indicated. Should be seeing the 1 bar flash this afternoon on the ride home if all is well. I'll then fill it up and see what happens. Fingers are crossed.
