aniwack
Don’t use aftermarket hoses. They explode when submerged.
ECU failed.
IT IS NOT THE KNOCK SENSOR.
Does getting a police ecu mean you don't have to reprogram your keys?Yes, a police bike ST1300 ECU. Note changes were made in '08. I forget what year your bike is, an 04? if so, anything up to a 07 will work.
I finally decided to clean my 5 way tee, next to last resort. When I got on there ,their were two 5 way tees. The small one disconnected from map sensor ,the other from black canister on right side .which one is nessacary?@@Last night while riding in hot weather the bike gave fault code 26. So I read about it here and went and cleaned the five way t connector under the tank. It was not completely blocked but one port was very restricted. After reassembly and reseting the computer the engine seems a lot smoother and I now wonder what all those little pipes do. Do they effect fuel and ignition timing?
I also noticed at the time of the fault code that the bike was running a lot hotter than normal and seemed to lack power and surge a little.
I don’t know if the problem has been solved yet but the engine now sounds very nice, smooth and zippy up to 8K while on the stand. Will ride it later when its cooled down to around. 90 degrees.
The bike’s got premium fuel with up to 10% ethanol in it at the moment. I don’t like that and wonder if that has anything to do with this issue in hot weather.
Mine's 04How old is your bike? My 07 ABS does not have a chip in the keys.
Mine's 04
My keys came with a little metal tag with 8 numbers,I need that code to make a new key.
