racer1735 said:
I thought I was just beginning to figure it all out, then he started talking about amperes and voltage...now I'm confused again.
No wonder I never passed 12th grade trigonometry!
Well I don't expect anyone to figure it all out here and you have to start somewhere right?
Unless you have a lot of things to connect and have no expierence you can bet that someone has done the wiring job that you need to do and you can ask questions about your specific application. Do I think anyone is going to whip out a calculator and starting punching in Ohm's Law while they're wiring the bike? No. But if you set up a simple rig to do some testing with you can play with maybe a device that you don't care if you ruin to learn some things.
The most basic thing you can do is wire up a power cable for a device an use the little multimeter to measure the voltage on the power plug. If you have something north of 12V you're pretty much set in 90% of the cases. A few devices use less than 12V so you do have to look at the documentation to make sure but again other people have probably mounted the same thing so ask questions if you don't know.
Voltage is a difference in potential, which is how is was described to me years ago, but even after years of doing this that description still seems vague. But think of it this way (and for those of you that know this I know there's an equal and opposite explanation) voltage rolls down hill. I have a postive 12V at the battery or on a wire from the bike but that 12V doesn't do any good with a ground. Why? Voltage is only a difference in potential and doesn't do us any good. It's comparable to a faucet that isn't turned on. Sure there's the potential to make water flow because there's pressure behind that faucet but unless we turn the knob the water isn't going anywhere. So unless you hook up something to that 12V it's not going to do anything. A discussion about voltage is useless though because current is what makes things happen.
Now I know there's 4 items but here we'll just talk about voltage which can be measured easily with a meter and current which makes things work. We said that voltage is a difference in potential like a bowling ball sitting on top of a hill. It has the potential to do work but in order for the work to be done you have to push it (flip a switch) so that it does useful work. That work of the ball following a path down the hill is similar the current. (science alert) Current is the flow of free electrons in a conductor. That flow is what allows a device to operate. You can stick 12V on a device but with no path to ground current cannot flow and no work is done. Once you hook up ground to let that 12V flow through the device to ground you've completed a circuit and sent the bowling ball rolling down the hill or allowed the water to flow from the faucet to the drain.
There's more obviously because there's still the 4 components of basic DC theory and they are all have a linear relationship to each other basically.
The hardest part about understanding the theory is making the jump from theory to practical applications which to be honest is all anyone here is interested in, including myself.
I probably won't be able to teach you everything you need to be comfortable with wiring but it is a goal of mine to at least give you a place to start. The problem with that is everyone wants to start in a different place. If I know where you want to start I may be able to help. If you start thinking about this stuff in general then you're trying to grasp the theory and that's hard to do all at once. However if you think about what's the first question that goes through your head when you take the first step to wire something to the bike. If that's your starting point then voltage is your first concern. Current is a by product here and it's going to happen whether you worry about it or not.
Here's an idea I just had. To worry about all this crap at once will cause a conniption fit every time so maybe here's a way to approach it.
What are you worried about? What DC component do you care about?
Wiring up a device: Voltage (volts, E)
Do I have 12V or what ever the device requires on the power cable I just hooked up to the bike.
Fuses: Current (amps, I)
Do I have a big enough fuse to handle the device I'm hooking up. Or I'm blowing a fuse. Is there something wrong with the device or do I need a bigger fuse. Is the fuse located very close to where this power cable connects to the bike/battery to protect the bike. Do I have a short (12V touch direct ground/frame) somewhere in the cable?
Connections: Resistance (ohms, R)
I've made a wiring harness to go to a device and how do I know it's good. Is the ground wire grounded and is the 12V wire hooked to 12V. I've powered up the device but it turns on and off by itself when I ride/sit on/look at the bike.
Charging System (battery charge/discharge): Power (watts, P)
I'm going to or have a bunch of stuff wired up the bike and now I'm worried about there being too much stuff and I don't know if the bike can handle all of it or not. If there's too much stuff that requires a lot of power then the battery won't get enough juice from the alternator to keep it charged. Now you can look at voltage here but knowing the total power consuption of your devices is what you need to learn so you can eliminate ones that aren't as important as others or learn what you can have turned on at the same time. Power consumption is only going to be an issue really if you are using heated clothing/grips and/or additional lighting (HID/Halogen). LED lights a VERY low power consumption. That's why they are great for bikes.
Am I getting warmer here or is it still in the state of don't know what to ask?
Curt
