I run a small hardened wire through the hoses and tee, didn't see anything, but felt something when I blowed compressed air.I could blow through it so figured it was clearYes, did you get any crap out of the lines or tee?
I would be interested in finding a way to disrupt the ecu's ability to retard the timing, you know like cut a wire ,ok jackass now screw with the timing.When traveling at a steady speed & throttle lock in place, I can notice a very small power loss when the light turns on.
It does feel a lot like the timing is retarded to a "default" setting to ensure that there is no engine knock, so that's what I'm guessing is going on.
So far, I've put over 2,000 miles with this error... I'm debating whether it's even worth trying to fix.
I'm looking at $1,000+ to fix a bike worth maybe $3,000... and already has 70,000 miles on it.
I may be better off just pulling the FI light out of the dash and forgetting about it.
My 04 started lighting just out of blue while riding it one day,l thought huh, what's this light doing. Rode like that for a couple wks.turn it off& on light goes out,ride comes back on. I replaced the sensor, 134 bucks from partzilla. Low and BEHOLD the light went out. But it didn't last very long,just a few days, what's up with that?It's not the knock sensor. It's never the knock sensor.
The ECU is bad.
The ECU is bad.
Because you replaced the knock sensor switch and not the ecu.My 04 started lighting just out of blue while riding it one day,l thought huh, what's this light doing. Rode like that for a couple wks.turn it off& on light goes out,ride comes back on. I replaced the sensor, 134 bucks from partzilla. Low and BEHOLD the light went out. But it didn't last very long,just a few days, what's up with that?
I finally had enough and waved the white flag in surrender. Called Honda and scheduled a diagnostic appointment, they said there tool didn't recognize the ecu, like it wasn't there, they assumed bad ecu or bad wiring since there was already some rodent damage in it, but had checked it for continuity every that I could see checked good, so at the earging of several people on this forum the ecu is the next move. I thankyou for all of your advice.The ECU advances the timing until it hears a knock and then it backs it off until the knock has gone. This system has limited options. I don’t think the knock circuit has a fault, I think a knock actually occurs because of ECU error. Perhaps it is advancing the timing as it should but it is not backing it off when it hears a knock where the timing changes above 4K RPM.
I think every brand has there own proprietary diagnostic tool,you have to be a dealer to get one. Yes they wrote up a repair order,wire harness 910.77 sub hermes's 98.01 and pgm-fi 1155.72 840 labor. I just paid my 1 he. diagnostic fee and left.I would love to know what diagnostic tool they used that didn't recognize the ECU....
Most shops, will just start throwing parts at it (generating revenue) until its fixed. This can be quite costly at $100 bucks an hour at most shops.
I'm guessing that in the end, they will tell you they had to replace the sub harness, ECU, injector wires, and all kinds of stuff that you may not have needed.
Demand ALL the old parts, and don't accept "we have to keep them to mail them to Honda for repair jobs" BS.
Does anyone have the part number fore the ECUTo be fair....for those that work on a lot of these bikes, and see certain failures often, you can be pretty accurate in knowing what your going to find wrong.
Most the folks that contact me before they ride in to my garage, are asked a few similar questions, mileage, age, location, service history, etc.
I then have them order the parts that I think they will need, and have them drop ship the stuff at my place, so it will be waiting for them when they arrive.
The funny thing is, the look on their faces, as we start taking stuff apart and examining stuff, and they are shocked that every single piece that was suggested that they would need, was indeed used and needed!
Its very rare that I have any left over parts.
Or......03 to 07 st 1300 ecu part # 38770-MCS-LO1
$1155 through Honda.
Thanks for the tip, I"ll givem a jingle.Or......
PGM-FI UNIT
38770-MCS-L01
Retail Price: $1,155.72
Your Price: $813.62
Through Ronayers.com
