I've checked wires for continuity& shorts on both sides all good,I've replaced the sensor that fixed it for a few days, now the light back on. Funny thing, tested sensor for resistance, or continuity there is none. Did my new sensor go bad
I checked my sensor in that manner, and did register a brief small voltage.but when testing for continuity,it's open circuit.Knock sensors are basically piezo electric microphones. They generate a small voltage when a vibration is detected. You can check them with a digital voltmeter. Pos probe to the pin on the sensor, ground the other probe to engine block. Set meter to lowest AC volt setting if not an autoranging meter. Tap on the engine block or sensor itself and you should see a voltage readout albeit a small one.
Thanks , Paul the answer I've been looking for. Do you know if there's a way to determine if ecu is bad?
Clear your codes, then go riding, and keep it below 4k RPM, and see if your codes come back.Thanks , Paul the answer I've been looking for. Do you know if there's a way to determine if ecu is bad?
So your saying ,my 04 civilian 2nd owner bike can through a 26 code below 4k if ecu is good? Mine never lights untill I exceed 4000rpms for about 10 secs.yesterday I removed the airbox and found rodent damaged wires going to the injectors,mostly just the insulation, I checked the wires for continuity all still good,so I taped them up. Also removed the small 5 way tee.and run a wire through it and blowed it out. It still lights up after 4k.Clear your codes, then go riding, and keep it below 4k RPM, and see if your codes come back.
"If your ECU is going bad, it will throw the code if you hold the throttle above 4k RPM for a few moments.
Did you inspect/clean your 5 way tee?
I would do that before you start throwing money around on replacing stuff you may not need.
What year is your bike, and how many miles on it?
Civilian model or PD?
Auction bike?
Yes I removed,and rodded tubes and tee. Now this is the one that attaches to map sensor?No, I am saying a defective ecu commonly throws codes above 4K rpm, but usually not below 4K rpm etc.
Again, have you inspected your 5way t and or replaced the vacuum lines yet?
Its not resistance it makes voltage . and the way it works is the ecm at a predetermined point will keep advancing the timing till it see a knock. (you will not notice it) the it will retard the timing so it has the most advantageous timing. In auto (work the same way) you can get a code if there is too much uncontrolled knock or none at all. I presume that when the code(light) is activated it goes into a limp mode timing so it doesn't cause engine damage.cant remember much about piezio applications, but just wondering if you could simulate one with a resistor or couple of electronics to I the ECM that all is fine, there is so much ____ reformulated gasoline out there that maybe (in the interest of being concise), god is trying to tell you something, these things are like, 10.6 or 10.8 : 1 (tell you exactly come October), my take is the last hard look these CR / fixed ign Curves / o2 content / real fuel value had was ten years ago, I know with the carbed bikes its getting to where you really have to rejet not only the mains.
I believe so.
When traveling at a steady speed & throttle lock in place, I can notice a very small power loss when the light turns on.
It does feel a lot like the timing is retarded to a "default" setting to ensure that there is no engine knock, so that's what I'm guessing is going on.
So far, I've put over 2,000 miles with this error... I'm debating whether it's even worth trying to fix.
I'm looking at $1,000+ to fix a bike worth maybe $3,000... and already has 70,000 miles on it.
I may be better off just pulling the FI light out of the dash and forgetting about it.
