Just had the same problem occur. (80mph 5th gear, passing a car, 75% throttle, level highway, 6am, 40°F, dew on the ground at most) I initially considered bleeding the clutch but as someone stated most clutches default closed and open under pressure.
I think it was Mark who suggested a tank of bad gas causing the knock sensor to adjust engine on the fly, of the ideas in this thread this theory makes the most since to me. I ONLY get this issue in 5th gear around 80-100 under a load (ie getting on it). It will still pull the front wheel off the ground in 1st and 2nd so I'm thinking it's not the actual clutch or fluid compression.
I wish this thread were more helpful, people trying to correct the last guy rather than build on an idea based on their experience.
I'll post again if I discover anything.
