I'm having charging issues. It looks like it will charge if the usb that is plugged in is held down but not if it is simply inserted. Wondering if anyone has had similar issues and if so were you able to find a fix?
TIL, good to know, thanks!Are you using the cord that came with it or an aftermarket?
I know on a lot of the older GPS systems the old USB 'snout' that plugged into the device was longer than standard.
If you used a 'standard' one it sometimes would not charge.
I fear the same faith on the Sena... those micro USBs are really hard to plug in...Apparently Cardo has experienced a failure rate with some of there units.
How did the repair go? I did the rounds of various shops here and none would touch it. Will keep looking but now also considering just getting the Freecom 4X as I don't really need the mesh.Yes have the same issue I believe. If you hold it just right with a bit of pressure it will charge, soon as you let go it stops. Solder joint on the charging port is most likely cracked/broken. I have mine at a Electronics repair shop to see if he can fix it. Dropped it off last week.
Ted:How did the repair go? I did the rounds of various shops here and none would touch it. Will keep looking but now also considering just getting the Freecom 4X as I don't really need the mesh.
