tm= xx thousand miles and tkm = xx thousand km is my guess.I confess to not knowing what tm or tkm is
When mine would do this, it eventually turned out to be a fuel pump issue. It would restart almost immediately every time; has been fine since the pump was replaced, YMMV.
I have understood that fuel pump issue causes engine stop and it would not fire up again. I can drive several thousand kilometers with no issues. And sometimes when leaving my carage engine stop while driving. After a while it again fires up and runs fine during whole trip. It's really confusing.If you are certain that there are no other electrical faults that appear at the same time that this happens would seem to indicate that this is not a ground/earth problem.
My first thought is that it sounds like the beginning stages of failure in the fuel delivery system, which is usually the fuel pump itself but not always.
It would help to locate the problem if ECM could show the fault code when engine shuts off. But no fault code.As in computers, and in other things, some of the hardest problems to identify are the intermittent ones.
In a general sense, it often points to a component that is failing.
Or, as in The Sixth Sense, it just doesn't realize it's dead yet.
what does the speed sensor do and where is it?Battery
Grounds
Fuel pump
Speed sensor switch
Does the clock reset to 0100?
Just because you hear the fuel pump wind up and try to prime, does not mean it’s holding pressure.
Check fuel pump flow, and fuel line hoses.
can that sensor be triggered with tip over do you think maybe?Tip over sensor...??
And you turn the ignition key off and back on.Shuts off motor in case of a tip over. Should reset when bike is upright.
Because fault doesn't remain and no fault codes exsists its really frustrating to search reason for engine shut offs. Engine "black out" takas only a few seconds there is not much time to check is there other electrical faults same time. And i have not managed to get fault on when running engine in my carage.If you are certain that there are no other electrical faults that appear at the same time that this happens would seem to indicate that this is not a ground/earth problem.
In my case I don't get any fault code but I think fault can be found when checking bank angle switch, bank angle realy, fuel pump realy and wires +connector related to those. And maybe fuel pump also?As in computers, and in other things, some of the hardest problems to identify are the intermittent ones.
All the lights are bright, horn Ok, switches are good as well. So fuel pump maybe the issue. Earlier owner didn' t drive much and bike was in carage longer times.Fuel pump keeps coming up ... and there was another member who had similar issues and testing fuel pump revealed it was week. Won't hurt any testing per manual just to take it out of the equation.
What are the load and no-load battery voltage readings?
What is the year and mileage?
Could it be the beginnings of alternator failure? ...
