I've had three of the brands mentioned here:
Battery Tender (numerous models; purchased, inherited, or given to me),
Optimate (I had an Optimate III that lasted a long time but eventually crapped out), and these days all I buy is
Battery Minder products (oh, and one
Motobatt charger for the fancy new "Hybrid" AGM/Lithium-Ion battery I just bought).
I did not need to buy the Motobatt charger but decided to anyway.
Observations:
- The battery tender stuff is... fine. It's fine. It's not great, it's not terrible. It'll do the job.
- The battery tender stuff charges to the lowest resting voltage.
- The battery minder stuff is superior IMO.
- Desulfating.
- For the 2012 model (and some others):
- Temperature compensation (in the nicer models); less voltage in hot weather, more voltage in colder weather, with safety params, etc.
- Phased charging; bulk charge to a higher voltage and then resting voltage is a bit lower for absorption. It also detects bad cells, a periodic load, and has other fanciness. This is the best charger I've ever used.
- At this moment the wall-wort model (12117; no fancy temperature compensation) is holding 13.6
- The optimate stuff is also fine, probably a bit fancier than battery tender but not fancy enough to justify the price hike.
- The motobatt charger I got will do "regular" batteries, AGM, Gel, and Lithium Ion.
- The motomatt seems to charge to a highest resting voltage (14.2-ish)
- I think it's a bit high but <shrug>... motobatt battery, motobatt charger.
Now. Some anecdotes:
I used the wall-wort battery minder (which desulfates but doesn't have temperature compensation) on a car battery. I got 8.5 years out of it (in Wisconsin, that's remarkable) before it
just started showing signs of going soft.
Last year, I needed a new battery to replace the DEKA that lasted 3 years. I was in a hurry and bought a Batteries Plus battery. I've had "ok" luck with these. A friend bought an identical battery the same day from the same place for his Super Tenere. Neither lasted a year. An even more desperate purchase of a Super Start (normally a good car battery) from O'Reilly lasted
less than a year for me. In all cases if the bike sits for more than a few days it goes on the charger. The batteries in my other bikes have lasted up to 9 years with the exact same charger (Battery Minder) and charging policy, but different battery brands. I replaced the battery this spring with a Motobatt Hybrid.
Do I think the charger makes a difference? Yes.
I have a Battery Minder 12117 (wall wort), Battery Minder 2012 (my favorite, with temperature compensation), and as I noted a Motobatt MBRC1.
I gave away everything else, and it was nearly a decade after I gave away the Optimate III that it died. It was probably .... 15-20 years old then.
