I think I just got my intro to heat shrink at:
http://www.ebay.com/gds/How-to-Use-Heat-Shrink-Tubing-/10000000177771507/g.html
1) Thank you for pointing up the simple alternative to soldering. Any pointers re "quality" for crimping tool and/or heat shrink tubing vendors? My principal resources seem to be Harbor Freight and Home Depot. We have Fry's Electronics which used to be great, so I'll probably look there. I just don't know any brand names or characteristics to look for.
2) Also, since it may be time to get a dremel, I know the last few times I looked them over at Home Depot, there was quite a variety and range of prices. Some stuff was proper Dremel, but those seemed to be in the $100+ range, while the imitators had little kits as low as $15 - $18. Presuming I just need a small kit of cutting disks, are the cheap ones OK?
3) When eliminating the 3P, you just twist the wires together and heat shrink over them, no solder?
So, the path seems clear: snip wires at base of 6P, solder on new female spades, opening one (red/white) as necessary, presuming I can't purchase the right size (I don't think I'll try to shave down the VRR-side male terminal for the red/white, since I don't have a Dremel anyway).
No no! Use a butt connector and after shrinkwrapping to seal/waterproof them, zip-tie the bundle of them to the frame to minimize any movement/flexing.
Actually, I never thought of John's idea about dremeling the male connector, since I also don't own one, but that would be a better idea than opening the spade, which may produce a less secure connection on that red/white terminal. That one is the one that supplies the DC voltage to the battery, so a solid connection is important.
After passing the dynamic AC test, I put a new spade on the yellow wire that needed one, hitched things up, and got a measly 12.2 across the battery posts at 3500 rpm, after the engine was warmed up.
Readings are too low.
**One of the three windings may be intermittent (as engine heats up; vibration).
One of the three yellow leads between the red 3P and the white 6P may have high resistance (corrosion, cut).
Battery (load test?).
Defective new VRR?
**edit: do the dynamic AC test again with engine hot and those same low readings are happening.
[$180 would go a long ways towards a 40amp. Sorry...]
A question that persists:
As laid out somewhere upstream, the 6P was found to have a badly melted-in (burned black plastic surrounding) spade on the yellow wire next to the wall of the VRR adjacent to the bike (VRR pin #5, per manual page 17-8). That wire was cut back and re-spaded prior to new VRR testing.
The melting/burning should have occurred for one of two reasons, I'd think: 1) real bad, corrosion-induced resistance just below the original spade; or, 2) the diode/circuitry (in the old VRR) that runs off pin #5 died, yielding extreme resistance at the pin/spade interface.
Given that there was clearly deadly resistance at the spade, could trouble back up to the alternator, and have made the alternator the problem?
