Shuey
- Joined
- Jul 3, 2007
- Messages
- 2,077
- Location
- Niceville, FL
- Bike
- FJR1300 ES, 2018
- SPOT
- LINK
- STOC #
- 7005
There have been reports (on fjrforum.com) of the rear sub-frame cracking on pre-2013 FJRs. I don't think that part of the structure has been updated for 2013+ so whatever the cause was still applies. That being said, who knows how much weight and how often the victims were subjected to?
I ride with both side bags and trunk attached all the time, and no issues so far. But they are very lightly loaded.
I think Yamaha's admonition not to do it is because people who do so would tend to overload them...
There is a GIVI rack available that mitigates the rear subframe weakness problem SR357 or 657 or something. It replaces the rear rack and side grab rails and attaches in a way that spreads the weight of the top box out better. I don't have one.
Don't get the OEM trunk. The inside is much smaller than the outside due to it's double wall construction. I chose the Shad 50.
HTH
-STeve
Thanks Steve. Just read an interesting and confirming post on an FJR site. I've already replaced the stock rear rack which also has the side grab rails. I've switched to Pelican Boxes for my top box two bikes ago. They're easier to pack since the corners are 90 degrees instead of Givi's more aerodynamic rounded ones.
I'm going to take a closer look at the sub-frame though and see what can be done. Even if it only happens to 1:1,00,000 . . . I don't want to be 'the one.' Forewarned is forearmed.
Shuey
