Hello all,
Picked up a free 1994 ST1100 with all the plastics and title because the guy was tired of dealing with trying to work on it. I figured for the cost of $0 I could give it a shot.
Came with a note about the issues he was running into and one seemed interesting so I thought I would ask here. Basically according to the note the fuel pump will prime normally when the key is turned to on, but then it says that the fuel pump electrical must be disconnected for the bike to start and it will run until the carb bowls empty. So if the fuel pump will prime it sounds like it works, so maybe the fuel pump relay is the issue? Once the pump stops priming after 3 seconds and is shut off it is then supposed to kick back on when the engine is running, but doesn’t? Also seems weird that it cannot stay plugged in or it will kill the bike. I would just try a new relay but it has to be Honda OEM apparently and they are not cheap as a maybe fix.
I still need to dig into it myself but I thought maybe this was a somewhat common ST issue that others might be aware of. TIA.
