Ha.....Hold my beer, I got this.....
Glad to see ya back Larry...!!!!
T
Ha.....
T
Make sure that it isn't really the fuel pump that the ECM has disabled ......it’s probably something much simpler like a fuel pump issue etc.
Being that you are a new member and located in Spain... do you have any info to share with previous repairs you've done so the membership will feel safe sending you anything?Hello everyone
I am looking for some faulty ECM to do tests and be able to repair the problem, I have already repaired this problem with other Honda models but I do not have any Honda ST ECM to do forensic work and make a diagnosis to be able to solve the problem.
Does anyone offer to send me their faulty ecm to investigate?
I need several units
Dado que es un miembro nuevo y se encuentra en España... ¿tiene alguna información que compartir con reparaciones anteriores que haya realizado para que los miembros se sientan seguros enviándole algo?
[/CITA]
yo soy el tecnico que repara las ecm de las goldwing
yo soy el tecnico que repara las ecm de las goldwingBeing that you are a new member and located in Spain... do you have any info to share with previous repairs you've done so the membership will feel safe sending you anything?
Please use english on the site since that is what everyone here is using.yo soy el tecnico que repara las ecm de las goldwing
okPlease use english on the site since that is what everyone here is using.
yo soy el tecnico que repara las ecm de las Goldwing
yes"I repair the Wing's ECMs. "
Where in Spain are you located?Of course, I pay the shipping costs.
JaenWhere in Spain are you located?
I bought the last units of that chip that were availableCould you go into what you were able to do to repair the Wing's ECU (I suppose pre-2018)?
Previous posts seem to suggest that the failure point is the chip that pings the Knock Sensor and passes instructions on to the CPU, and that there are no replacements available for this component.
Did you find a way to emulate this chip?
Or pass "fake" info to the CPU to make it believe that all is fine with the Knock Sensor communications?
It is not the same, and there is no stock for the one from st.Is your aim at this time to check if the Knock Processor Chip used on the ST ECU is the same as the Wings' you amazingly managed to secure?
