- Joined
- Oct 26, 2020
- Messages
- 2,008
- Location
- Makefield Highlands PA
- Bike
- 2016 ST1300P
- 2025 Miles
- 000104
For the sake of the viewers out there, Larry and I talked last night and he thinks the “additional gear” may be giving the suspension a rear bias. Going to increase the preload, ride and see. Will report back. I already use Ride On.I'm guessing it was liability issues from your Dark Side Choice
Pick up a bottle of Ride On, remove the schrader valve from the front tire, and squeeze in the whole 8 oz bottle of ride on then air the tire back up.
This should balance your tire for you.
You do not need to remove the tire to balance it.
Are you sure its the tire?
Make sure nothing loosened up on you! Check your axle nut, pinch bolts, triple tree bolts, etc.
Don't worry about that shop, put it behind you, and keep enjoying the journey of a lifetime, don't let them upset your journey.
Ride safe my Friend.
Larry
And for you out there that are new to the show, everyone here helps everyone. This place is great!
Thank you Larry!!
My campsite in the middle of the night.
