I am with the Pop-Pop he will make it!Hell, it weighs only 700 lbs! I can push it home.
$10 says i can make it!
Ok but you have to admit your complete humilificationYour on
But trying to get a rear tire for a ST1100 on the road is even less fun than that!U r absoloutely no fun at all!
The rear 160-70-17 was a size used on early Harleys, before they changed frame to accept wider sizes. They even had a Dunlop tire with "Harley" on the side wall. You could then claim you rode your Harley home, pointing to the tire.But trying to get a rear tire for a ST1100 on the road is even less fun than that!![]()
As it turns out, the rear for the BMW K1200LT is also the same size as the ST1100 as I use the BStone version regularly.The rear 160-70-17 was a size used on early Harleys, before they changed frame to accept wider sizes. They even had a Dunlop tire with "Harley" on the side wall. You could then claim you rode your Harley home, pointing to the tire.An option, should the need arise.
Or at the very least, not costing more than you paid for the tire.The challenge is finding the tire and then finding someone to change it that won't cost you more than the bike is worth.![]()
Thank tou, but i think i have enough rubber to get home. Just checked the preassure and by golly, the tire still has air in it! Im not thru the wear bars yet and am not planning any wheelies or burn outs, so im fairly confident.Ok, ok - I have a rear tire that I took off my ST1100 prematurely because of a flat. The staple holes have been patched from the inside. There is a powersports dealer in Elkins - so, Mike if you want this tire, just check to see if the dealer will mount it for you. Then let me know.
Ray
I remember you used these same kind of tires on your spring tour at around 10,000 miles as well. I say you are cheating and you already know you got some miles left. Just don't go looking for a nail to test the tread depth.Thank tou, but i think i have enough rubber to get home. Just checked the preassure and by golly, the tire still has air in it! Im not thru the wear bars yet and am not planning any wheelies or burn outs, so im fairly confident.
many thanks to all. Plus, someone took me up on a bet, so its pride before brains now!
im trying to decide if im heading straight home or to the wv stok. The meet is a bit out of the way, but not much. Something to ponder asi roll along today.
Cheating? Im from boston! We only cheat when it involves money, wives, pride, property, ego etc! I would NEVER cheat!I remember you used these same kind of tires on your spring tour at around 10,000 miles as well. I say you are cheating and you already know you got some miles left. Just don't go looking for a nail to test the tread depth.
Well, if i change my odometer to k’s, ill feel like i rode further!You want to put bridgestone H50's on and get at least 15-18 k on it.
K means thousandsWell, if i change my odometer to k’s, ill feel like i rode further!
