Ill bet you r a hot dogger! I guess i cant return these tires for a refund!If you got 10k out of that so far, another 1k is probably not going to be an issue. I can't ever get more than 8k our of a rear tire but that's a different issue.
I prefer hamburgers, thank you very much!Ill bet you r a hot dogger! I guess i cant return these tires for a refund!
And this is why i continue to put the cart before the horse!Well stop drilling holes in it with that tool and you wouldn't have to plugit!! Russ
Ill make believe im riding out west in the afternoon!Or ride it leaning 60 degrees to the right then alternate half way home, to the left.
You are also riding to cooler weather and roads, that may help slow down the wear somewhat.
My $$ is on getting home!Ill make believe im riding out west in the afternoon!
Brilliant... sounds like a good plan to me!I'm reminded of the guy who was getting low on gas so he sped up to 90 to get to the station before he ran out!!![]()
You are the eternal optimist!If he does run out of gas, just think how far he can coast!![]()
U r absoloutely no fun at all!Gentle on the throttle on your 'take-offs' and on your braking and you will probably be fine.
Your onHell, it weighs only 700 lbs! I can push it home.
$10 says i can make it!
