Sadlsor
Huh.Especially if it is attached to a VFR800!
Especially if it is attached to a single-sided swingarm.
Lol, yup, 20 some years of VFRs kinda sticks with you....rear wheel off the bike in 5 minutes, while sipping a fav IPA.Especially if it is attached to a VFR800!
I don't think anybody else has mentioned that I don't see any sign of a centerstand. The way the exhaust is routed under the engine I'm not sure its going to have one. I toured for quite a few years on an FZR1000 with no centerstand, I had a piece of 1" PVC that was cut so that I could lift the rear wheel off the ground by levering it onto the sidestand and put the PVC under the ample swingarm to support the load while doing chain lubrication (or adjustment for that matter). I'd need to get a closer look at the swingarm detail to see if that would even be an option with this bike.It's Chain Drive - Bah, Humbug!![]()
5.0 UShow about replacing those tac- lights with some real headlights then there is that issue of gas, how much does it hold
Funny, my first impression was it's design was influenced by bugs. And it is 'edgy'.Still, not too insect-y looking for a new bike, so there's that.
I was an early adopter of the Scott Oiler, and there are alternatives available now, though I've never used another.I too prefer shaft drive, but adding an automatic chain oiler takes much of the hassle of spraying the chain away.
Euro 5, I know, I know.5.0 US
Besides the engine based on the high rpm liter bike GSX-R motor, what does this entry bring that the Bandit FA did not?
only 5 gallons, i need a rack to put my fuel cell on and somewhere to add some extra driving lights5.0 US
So exactly the same fuel capacity as a GL1000 and probably better economy and Suzuki should try harder?Boy, I hope some of you are never on my jury... guilty until proven innocent based upon my looks and my cousin's hooligan history!
From what I've actually read, it seems that the bike has been designed as a tourer, at least according to Suzuki.. Some things that stuck out to me...
I'll have to admit the windscreen looks like it won't do much, but Suzuki says they did a lot of wind tunnel testing, so it is what it is. They'll offer a larger version. I've never owned a Suzuki, but overall, I think it sounds pretty good and look forward to some actual rider reviews.
- 6 speed, 150 HP
- 5 gallon fuel tank (wish it were more)
- 46 mpg
- CC, heated grips
- ABS/TC
- Quickshifter
- 36L panniers that hold a helmet
- LEDs all around
- 500 lbs
- Smartphone integration
- 6.5" TFT display
- "reasonable sport touring riding position "
- "powered by a street tuned version of the GSX-R sportbike’s 999cc, in-line four-cylinder engine, which has been updated with a revised intake and exhaust camshafts, cam chain tensioners, valve springs, and redesigned clutch and gearshift components. Suzuki says the enhancements deliver a broader, more consistent torque curve while meeting Euro 5 emissions compliance standards."
