Had bike about a year and rear brake peddle was always soft and had too much travel, but did work. A couple of weeks a ago I bleed system but didn't bleed the SMC. On first ride rear peddle perfect. 2nd ride a week later no rear peddle at all-zero. So started over and followed the proper sequence. Removed SMC and elevated to 15degrees, at PCV I could not get a continual flow of fluid. It flowed a few seconds but had a lot of air, level in rear reservoir dropped as expected. Then it just stopped, will hold constant vacuum with bleed nipple open. Went to front right caliper center nipple and it free flows air, can't build vacuum. As anyone seen anything like this before? It seems like maybe the PCV is stuck or there is a leak due to a ruptured hose or something?
