T_C said:and hit welded area with hammer.
The tank isn't the only thing that will 'clang'. I read your words but would really have to get comfortable with the science before I tried that. LOL!
It's a MIG with Zargon and I've got good tips. I got the metal pretty clean with just carb cleaner. They must not prime these tanks and probably just spray them quick and slap stickers on it.Go ahead and try it. Ingersoll Rand was a good name in air tools; I'd expect far higher quality than a HF compressor. Maybe, like BakerBoy said, its coated on the inside. I'd suggest you grind the outside of the weld clean, and the surrounding area if you will be laying down parallel beads.
If you are using MIG, for short circuit transfer (up to 3/16" inch) you should be using a flush nozzle and maintain a a 1/2" contact tip to work distance.
I've got to brown some meat for chill tonight because I'm out the door early tomorrow. I'm riding into Canada to meet with a friend to ride back into Spokane. He's been on a 5 day trip and I'm sure lunch will be full of stories. Chili should be done by the time we arrive:eat2:
As a side note, what's the quietest compressor out there? I totally get that the old ones were super quiet...ff
Looking at pictures 3 & 4: Is that the drain tube sticking up from the drain valve?
I have an very old compressor that had the same thing happen. I was using it painting and had no time to play with it. I stuck a sheet metal screw in it with some never-seize on it, to help the screw from rusting and that was 4 years ago. And by the way the compressor tank will not explode and send shrapnel flying like some other post had mentioned. It will just start hissing somewhere else.
I'll get struck by lightning twice before that happens.Al, while rare, they do explode. Here's one caught on video:
https://www.youtube.com/watch?v=KVP_A7eGYxw
Apparently the guy lived, after 3 mos in the hospital. And there are other examples not caught on camera but which show the splattered tank--they most often fail at the weld seams and spread open like a popped balloon.
Maybe you can post the chili recipe....:eat2:
now we have to see if his compressor blows up!!!:bsflag: its fake http://www.businessinsider.com/what-to-expect-when-you-survive-lightning-2016-4
