If you fellers see a loose nut take a picture will ya?
Come on, just go to Times Square around midnight on Dec. 31 and you will see lots of them. As a native New Yorker, it takes one to recognize one - and I've seen a lot of them.:bow1:
The bolt is literally stretched until it is deformed to apply the proper preload.
-- Any literature on that?
Ive removed a million cotter pins in my life time. Not one had a loose nut under it. Have you ever found one?
As a private pilot I see some wired on nuts on easy to get to things like the propeller. Maybe one in a hundred fasteners have wires to secure them. But if they arent easy to get to....no wires. thats 99% of the fasteners on my airplane. The sheet metal screws that hold the inspection covers in place arent possible to wire in place. They dont use loctite on em either. Been flying since '83. Theres hundreds of sheet metal screws on an airplane. Never saw a loose one. Not one
Between the angle torque spec, plus the different appearance, there were clues that these were not just ordinary bolts.
....just because the service manual says "use a new one" that does not necessarily imply a TTY bolt
Item | Size | Torque |
Middle Cowl mounting bolts | 6mm | 10Nm / 7 ft-lb |
Front Brake disc bolt | 6mm | 20Nm / 14 ft-lb |
Rear brake disc bolt | 8mm | 42Nm / 31 ft-lb |
Rear Brake Caliper Stopper Bolt | 18mm | 69Nm /51 ft-lb |
Rear Shock Upper Mounting Bolt | 10mm | 42Nm / 31 ft-lb |
Front Brake Caliper Mounting Bolts | 8mm | 31Nm / 23 ft-lb |
Caliper Body B Bolt | 8mm | 32 Nm / 24 ft-lb |
Rear Master Cylinder Mount Bolt | 6mm | 12Nm / 9 ft-lb |
Pulsar Rings (both wheels) | 5mm | 8Nm / 6 ft-lb |
Side Stand Switch Bolt | 6mm | 10Nm / 7 ft/lb |
Centre Stand Pivot Stopper Bolt | 6mm | 12Nm / 9 ft-lb |
Handlebar Weight Mounting Screw | 6mm | 10Nm / 7ft-lb |
I don't wrench on as many things as I used to, so my experience with this topic is very limited. The only TTY bolts I've come across were on the cylinder head of my 1990 5-series BMW. Those bolts required a moderate initial torque (20-25 ft-lb) to snug them up, then they were spec'd to an angle torque of an additional 90 degrees for the TTY phase. I seem to recall the bolts were also necked down a bit between the head and the threads, so they looked different as well. Between the angle torque spec, plus the different appearance, there were clues that these were not just ordinary bolts. And they had torx heads too.
Is it common to come across TTY bolts that look just like any other fastener, and if so, how do you determine a particular bolt is TTY? I'm guessing that just because the service manual says "use a new one" that does not necessarily imply a TTY bolt that will positively fail if re-used.
Just to add a little more illumination or confusion to the issue of ALOC bolts - I went through the 'General Information' in the Shop Manual looking for other bolts that required a new ALOC bolt/screw to be fitted (Identified as 'Note 6' in my copy). Some may surprise you -
Item Size Torque Relative Tension Middle Cowl mounting bolts 6mm 10Nm / 7 ft-lb 42% Front Brake disc bolt 6mm 20Nm / 14 ft-lb 85% Rear brake disc bolt 8mm 42Nm / 31 ft-lb 100% Rear Brake Caliper Stopper Bolt 18mm 69Nm /51 ft-lb 32% Rear Shock Upper Mounting Bolt 10mm 42Nm / 31 ft-lb 64% Front Brake Caliper Mounting Bolts 8mm 31Nm / 23 ft-lb 74% Caliper Body B Bolt 8mm 32 Nm / 24 ft-lb 76% Rear Master Cylinder Mount Bolt 6mm 12Nm / 9 ft-lb 51% Pulsar Rings (both wheels) 5mm 8Nm / 6 ft-lb 49% Side Stand Switch Bolt 6mm 10Nm / 7 ft/lb 42% Centre Stand Pivot Stopper Bolt 6mm 12Nm / 9 ft-lb 51% Handlebar Weight Mounting Screw 6mm 10Nm / 7ft-lb 42%
And yes, the instructions do say to fit a new handlebar weight mounting screw.
Someone mentioned that certain bolts (head bolts?) can have deformed threads or be necked down somehow. Certainly any fastener like that should be replaced! And Ive certainly rebuilt engines with kits that include new head bolts. (although Ive never found any of the original head bolts with deformed threads)
Seems to me if you find deformed threads that indicates 1) the bolt was over-torqued on assembly or 2) defective for the application somehow.
Absolutely. Several sources. Here is Wikipedia, just as a start.
What am I missing here?
a purpose.
you're discussing a topic with a bunch of people who have no idea why Honda makes the decisions they do, and trying to guess at why something was decided 25 years ago on another continent.
If it makes you sleep better at night, replace the bolts that Honda recommends replacing. If you don't care, put the old one back in. How many ST bolt failures get reported here???.
