Well Eric, it does sound like you're on the trail of the clutch issue at least.
I had a local mechanic bleed my clutch last summer before a big trip and he reported that he got no fluid out until suddenly, a great big wad of what looked just like <please forgive the graphic image> - snot - came blasting into the reservoir of his vacuum bleeder. That didn't happen with the brakes - but the clutch sure had some bad stuff in the pipes. That was actually the beginning (I think) of my clutch slave cylinder woes (see article on replacing the CSC on this forum) - although it isn't entirely clear to me what the connection between the deteriorated hydraulic fluid and the slave cylinder seal failure might have been.
Anyhow, my bike is an '07 and I think I have determined that the routine maintenance had not been done by the P/O and so last summer was the first bleeding done on either the brakes or the clutch. At that point, the bike was 9 years old and had roughly 33,000 miles on it, although the miles aren't important - its the time that counts in terms of fluid deterioration.
Sooooo....if your bike has been sitting and you've got hydraulic issues, I would clean out the master cylinders (brake and clutch) - FIRST - and then bleed the systems very thoroughly until the fluid runs clear.
Pete
Pete
