What bulbs?just did my ST 1100
Yes the bulbs from Cindy. http://www.amazon.com/Headlight-Evi...sr=8-3&keywords=EVITEK h4&tag=viglink20849-20
Yes Raymond that's how it works.
There was an exchange earlier in the thread that suggested that the fan could be separated from the bulb.
I removed the fans from the bulbs.....then installed the bulbs with the clip....
Then slid the boots on....
There's a tendency not to reference what item someone's talking about or leave out important details in a long thread.
Or maybe I'm just being dense.
I used no shims on my ST1300. Just cut off the G6 lower two tabs from the base plate, and secure it where the old headlights bulb was located with the ST1300's retaining wire-clip.This mod needs to be done with the G6 Evitek as well for the 1300 so I assume the 1100 needs it too.
I did no modification to my ST1300 boots. After the base plate (less 2 tabs) is installed (without shims), the boot goes on next, then the LED/Fan assembly last.For the G6 the boot on the 1100 would probably need to be modded the same as the 1300 since the fan doesn't come off.
G6 Evitek is what I just installed with the adaptor on my 1300 and I didn't have to cut the boot. I used the adaptor because it lined up the bulb better.For the G6 the boot on the 1100 would probably need to be modded the same as the 1300 since the fan doesn't come off.
Maybe a bit of a heads up for Canadians. Seeing as how Canada Amazon doesn't carry these, I contacted Cyndee and ordered a set.
That was on Feb 20. No sign of them and Chinese tracking is, well......a bit lacking. As far as I can tell, they haven't left China yet. I contacted Cyndee 10 days ago and she said she would look into it. So far, I have heard nothing back. Hopefully they will show up and it was just a one time glitch but maybe hold off buying from China until this gets sorted out or Amazon.ca starts to carry them.
Rod
Ok so some boots were cut some and some weren't. Some adapters were used and some weren't. I hope that clears everything up.![]()
I chose to not use the spacer and not to cut the boot for my installation.
Rob,Thanks for the info.
A guy on the stromtrooper forum had his bulb defective out of the box, but he got them replaced via Amazon itself, not sure why you had to get the China shippingI bought 2 sets of these lights thru Amazon after reading this thread.
The first set went in my ST1300, the second set into my 2004 Toyota Tundra. The bulbs are an amazing improvement over the halogen H4 bulbs, brighter with good cut off. However.....
The tundra required load resistors to work properly. After getting them working, one bulbs' high beam quit working. After a few emails back and forth with evitek, they agreed to ship me a new bulb from China, but only after I cut the wires on the old bulb and sent them a photo of the cut wires.
I am not impressed with their customer service so far.
As I told them in my last email, Rather than waiting for a slow boat from China with only one working headlight, I'll order a new pair from Amazon and have them in 2 days, then send back the pair with the defective high beam.
I only hope the pair that went in the ST has better durability.
