Finally got the new water pump seal and the impeller out of the Honda Civic donor pump diameter turned down to 2.10 inches.
So I rebuilt my first ST1100 water pump. In April I plan to check for any interference of the new style cast iron impeller in my ST1100 . Then I am planning on rebuilding the water pump out of my ST1100 using a different style cast iron impeller and check it for interference. Then I'll install one of the rebuilts and check for proper operation.
Total cost was $50 for the Gates 41038 donor pump I bought from Rock Auto( bearing / shaft assy and impeller ) , new unitized seal, and labor to turn down the Civic impeller.
Here are some pics ( click on images for larger views ) :
New Unitized Pump Seal. Installed using Locktite 680.
Rebuilt Water Pump
Closer view of 1.3L Civic turned-down Cast Iron Impeller
The below image shows the donor parts from three different water pumps. All three impellers have been trimmed to about 2.10 inches / 53.3 mm in diameter. The center impeller was turned down on a lathe, the diameter of the other two were reduced using hand tools.
The original diameter was about 60 mm.
The impeller on the left is from an Airtex AW9069 water pump ( '85 Honda Civic 1.3L ).
The middle impeller is from a Gates 41038 water pump ( '85 Honda Civic 1.3L ) and is my favorite choice.
The impeller on the right is from an Gates 41040 water pump ( '90 Honda Civic 1.3L )
I bought the three pumps from Rock Auto. I think it's hard to beat their prices including shipping.
All three pumps have the same bearing / shaft assy.
The Airtex impeller is closest to the OEM impeller.
From what I have read, cast iron is a superior material compared to stamped steel for an impeller.
Personally, I like the circular impeller the best. But it costs a few extra $$ to have it turned down. But it may be more efficient in pumping the antifreeze solution ( use less power and a smoother flow ?? ). But I think the other cast iron impeller will work just fine.
Click image for larger view.
You can purchase an improved one-piece water pump seal from Kellogg Automotive in AZ. The seal PN is S2003 ML . It presses on a 12 mm shaft and has a 30 mm cup diameter. BTW, locating a source for the seal was the toughest task for this project. The actual rebuilding is a relatively easy job. You need a press - don't even think about pounding the new bearing / shaft assy to install it , or to even disassemble the old pump.
BTW, When disassembling the pump to be rebuilt, first remove the old impeller and drive pulley, and then press out the bearing / shaft assembly by pressing on the 12 mm end , not the 17 mm end. And you will need to fabricate a tool to install the seal properly. The Kellogg website has a diagram of the tool that they sell with dimensions. My home-brew tool doesn't look like the diagram, but it works exactly the same. I made mine out of two pieces of 1" galvanized pipe and a 12 mm fender washer spot welded together.
Parts Before Spot Welding and then after Spot Welding
The width of the small piece of 1" pipe is 0.35 inches. That's the required "installed" height of the seal. That will result in the proper preload of the spring that is part of the seal assy.
New seal inserted into tool. The 30 mm "cup" of the seal is visible on top. The "cup" of the seal is what is pressed into the water pump.
Edit: After you receive the new seal, measure the cup diameter with a micrometer. There is also a 1 1/8 inch diameter seal available. Make certain you received the 30 mm diameter cup version. I got the wrong seal sent on the first shipment.
Send me a pm if you have any questions or post your questions here. This has been a fun project, and I have learned a bit about water pumps.
Rebuilt Water Pump
