You guys are awesome! I have never had a drip anywhere I have ever parked, but taking your advice I have removed all tuperware and found a very faint dry green trail from the little water pump check hole. The overflow tank was dry, but the radiator was full. So Monday we will be ordering all the parts to replace the water pump. Looking at the service manual and the hydraulic press and other special tools needed, I guess I'll have to have the dealer change the water pump and thermostat at the same time. I wonder if I can save some money since all the tupperware is off and have them do a valve check/adjustment at the same time?
Is there anyone in Arizona that could help me do this myself; rather than going to the dealer?
Thank you again for all of your help. When the dealer did the radiator flush and refill they should have noticed the leak and told me at that time. Another dealer disappointment.
ST-Owners are awesome. I can't thank each and every one of you enough.
Before you go running off and buying a water pump....is the green stain coming out of the SQUARE hole or the ROUND hole? Big Difference!
Alot of times when you have a coolant leak, the water drains down from the Vee and exits the square hole, as it should, but sometimes the wind blows the exiting coolant
backwards onto the round hold giving the appearance that its leaking from there.
I'd take some simple green or windex and clean the area as best you can, then start the bike and bring it up to 3 bars and turn it off, then watch where the
leak comes from. I've also used arisol foot spray (white powder) to locate leaks by cleaning, spraying, then watching the leak appear before your eyes.
Anything leaking out the square hole indicates loose clamps up in the Vee area (VERY COMMON).
The service manuals are misleading as far as the round hole. Prior to 07 they clearly state if ANY thing leaks out the round hole, replace the waterpump and mechanical seal etc.
However, 07 and newer, Honda fabricated a threaded fitting onto the round hole and runs a OVERFLOW VENT TUBE down under the cowling, and states that a SLIGHT WEEPING
from this hose is normal. Some folks think this was done because Honda was replacing several waterpumps when customers complained about coolant leaks.
This was their fix.
I've got a new water pump, seal, gaskets and everything needed sitting in my tool box, because I believed the servcie manual the first time I found my leak.
After replacing the clamps, I found I didn't need the $250 dollar water pump :nuts1:
Just somthing to keep in mind.
I've not worked on ONE of these bikes yet, that didn't have a coolant leak, up to and including 09's and newer.
YMMV
