Does anyone know a good wrench in the PHX, San Diego or LA area to do engine work on an 1100.
Either a head gasket or worse issue.
What are the symptoms??
Head gasket failures on 1100s are not very common, unless somebody decided to run it with little or no coolant.
If it really needs a new head gasket, it might be more cost effective to find a salvage engine and do a replacement.
Does anyone know a good wrench in the PHX, …... area to do engine work on an 1100.
Bought an engine and need to finish the install. Swap the good stuff and put it back together. Was a cracked cylinder wall.
Isn't Igofar down there.
Still curious as to the circumstances that cause this... overheating?Bought an engine and need to finish the install. Swap the good stuff and put it back together. Was a cracked cylinder wall.
I don't know about anyone else, but I'd like to see a pic of the coffee table.Crud! I just gave away a well running ST1100 engine for free! The taker was just going to cut it in half, put glass on it and use it as a coffee table.
