Article [13] ST1300 - Wiring Schematic
North Plainfield, NJ
'06 ST1300A
Re: ST1300-Wiring Schematic
Now that's a good schematic. Adam was looking for something like this.
Quite a few connections missing from the alternator/fuseboxes on the ST1300A diagram, as is the 65A fuse. Maybe mice have been munching the wiring?
hmm....you're link doesn't work. That could be websense here at work.
Now the OP post #1 does not have the fusable link etc.
It did before lunch.
I think he meant a grid of 12 sheets of paper LOL.
+1 that is SO much easier than the shop manual.
Full size is around a D print and my eyes still squint LOL.
It appears to me that the fuses are probably the same through the years but locations have migrated. What I gather I am looking for is fuse J, but where fore art thou
reward fuse box of the two in there
left hand side
under the small fairing pc by the ctr stand lift assist handle
It occurs to me- do we have to remove the rear fender to change a brake light? The turn bulbs are easily accessible, but the ECe and ABS controller are so wedged in and retained with that infernal rubber strap that seems like it needs to be completely removed from where it "slides thru the plastic tray for the toolkit. I'd really prefer to splice into the brake lights near the end of the wire run, but it seems unusually difficult to access...
Thanks for the diagram. I am using the PC to trace the wires (can blow the size up and using the mouse/ gestures can simply scan/ follow the colour to sources.) Really usefull. Again Thanks... Im having a 2 low head lights blown, no charging and some type of shorting issue....
Just came across this. It's awesome. Thanks. We just got a 42" wide plotter at work so I had to print this for a test. Printed one actual size and one that is full 42" wide. Perfect.
