Shim change went well. Michael (CYYJ) was a great help sending me his shim kit! Ended up having to buy some though. I needed a few oddball sizes. 148,188 etc....
The left side cam chain tensioner didn't try to recoil back in, when I screwed it out. It felt stuck the whole way back. I didn't have to use vice grips to hold the position at all. The upper tensioner worked fine.
Once I removed the left side tensioner, it worked properly? I stuck my finger through the tensioner hole and that chain guide is hard to move. Maybe it tensions the chain better as the oil and heat start flowing? I ordered a new one anyways. You can also preload/add more tension to these tensioners, (Youtube) which is an option instead of buying new.
The "left" side cam chain would often get caught or bound up on the bottom once the cams were removed, even though I wired the chain up. I had the cams off at least three times and every time I went to install the final second cam, the chain wasn't long enough? I had to pull up on the chain a little and heard a little snap each time, then it was ok? It was getting kinked on the bottom crank sprocket somehow? I heard Larry Fine I believe, talk about that also on his 1100. Not sure why....
Doesn't matter which cam you take off first. I used paint marker to mark the sprockets and chains as well as line up the sprocket markings on the frame like stated in the shim chart sheet before retracting the tensioner and removing the cams.
Bike started fine and I did another throttle body sync. It was fine.
No big watch outs.....pretty straight forward , once you have done it at least once....
Added a few pictures. One shows how to read your feeler gauges easier once your eyes are starting to go
and I got a pic of how small the shims are.
