Article [13] ST1300 - Torque Numbers
002956
This is a place holder.
As you come across items you need torque numbers for, post them to this thread and I'll update the list.
Front Wheel
Front Axle Bolt ..................... 58 ft lbs - 78 Nm
Front Axle Pinch Bolt ............... 16 ft lbs - 22 Nm
Right Front Caliper Mounting Bolts .. 23 ft lbs - 31 Nm
Left Front Caliper Mounting Bolt .... 23 ft lbs - 31 Nm
Left Front Caliper Pivot Bolt ....... 23 ft lbs - 31 Nm
Rear Wheel
Rear Axle Bolt ...................... 80 ft lbs - 108 Nm
Muffler Band Bolt ................... 16 ft lbs - 22 Nm
Caliper Stopper Bolt ................ 51 ft lbs - 69 Nm
Muffler Band Bolts .................. 16 ft lbs - 22 Nm
Final Drive
FD Filler Cap ...................... 9 ft lbs - 12 Nm
FD Drain Bolt ..................... 14 ft lbs - 20 Nm
Here is a word doc that I made with many of the common torque numbers that I keep a printed copy of in my shop. On the back it has the front wheel mounting procedure.
Edit: I guess there is a little more on there as well. Some capacities, and specs like tire size, spark plug and gap, ect.
  • ST1300 Cheat Sheet.doc
Brake, PCV and clutch bleed bolt torque. I cannot remember the exact measurement, about 4, 4 & 6 ft/lbs, respectively.
Upper and lower shock bolts
