Model Year Changes
2002Model Year Changes
- ST1300/ST1300A Pan European introduced in Europe and Australia
- Pan Colors: Amazona green metallic; Tower silver metallic; Candy ambassador Red
- Recalls: High Speed Stability, Oil Pan
- ST1300/ST1300A introduced in US
- Non-ABS version also does not include the power windshield
- ST Color: Tower Silver
- Pan Colors: Tower silver metallic; Candy ambassador red
- Chassis modifications to correct high-speed wobble on 2002s
- Heavier fins on oil pan
- Recalls: Brake PCV, Ground Cap, Wire Harness
- ST1300P introduced to the law enforcement market
- ST Color: Pearl Coronado Blue
- Pan Colors: Digital silver metallic; Pearl Coronado blue; Candy graceful red; Shasta white (P model only)
- Power windshield standard equipment on all models
- Heat-related changes:
- Metal heat shielding over headers in lower cowl
- Vent holes in tip-over wings
- A number of other minor engineering changes which can be found by reading the service manual and the Parts Catalog.
- ST Color: Candy Graceful Red (marketed in the US Candy Dark Red)
- Pan Colors: Pearl Coronado Blue, Candy Graceful Red, Digital Silver Metallic, Shasta white (Police model only)
- ST Color: Black
- Pan Colors: Achilles Black Metallic, Candy Graceful Red, Digital Silver Metallic, Shasta white (Police model only)
- Tool kit reduced to a single hex wrench and a piece of foam.
- ST Color: Digital Silver Metallic
- Pan Colors:
- ST Color: Candy Glory Red
- Pan Colors:
- ABS tone wheel design changed from toothed to flat with holes.
- Covers added to voids in frame below side covers.
- Maintenance cover panel fasteners changed from plunger-type to screw-type
- Improved drainage on secondary master cylinder bracket (new part is 06454-MCS-G02)
- Added float to front brake master cylinder (P/N 45523-MN5-006)
- Changed the water pump weep hole to a fitting with a hose that runs to the bottom of the bike. (xyzzy - Need new part number)
- 30mm longer fork compression damper pistons
- Different ECM
- Front Brake Pads Changes - new part number: 06455-MCS-R02
- Added more catalyst to the muffler, making them hotter and more expensive to replace
- Added lower side covers to help keep the heat down from the "improved" mufflers(catalyst)
- Recalls: Rear Brake Hose
- No known changes from 2008.
- No known changes from 2009.
- No known changes.
- No known changes.
- Only Police model available in the U.S.
- No known changes.
- Recalls (Police model): Starter Relay Switch
