- Joined
- Mar 18, 2006
- Messages
- 2,871
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
An invaluable aid to the identification of electrical faults which result in the fuel pump not working on the ST1300. If you think that you cannot read an electrical circuit, try this. It takes you by the hand and leads you through the diagrams one step at a time.
The Fuel Pump Circuit has been the source of a number of electrical woes, and it is particularly awkward to work out what is going on from the main circuit diagram.
In fact, it is quite straight forward - a cascade of three individual relay circuits, each one turning on the next. A simplified version taken from the ST1300 Honda manuals is drawn above. The attached pdf file describes the circuit step by step, describes what the relays look like on the bike and how to determine which part of the circuit has failed. It even tells you exactly where to probe with your multimeter and what results you can expect if the circuit is working, and what to expect if it is failing.
Then there are 5 different scenarios or puzzles to get your brain around.
There are two versions attached, both identical, except that the left hand pdf has the answers on the back page; the right hand pdf has the answers at the bottom of each page.
