I'm currently on a 1100 but am considering a 1300.
I read 92 octane or higher - is this right?
Are they Premium unleaded only?
Thanks!
Thanks!
The 1300 is designed to run at it's best on 91 or better octane but it does have knock sensors allowing it to run smoothly on 87 albeit with slightly less power.
Thanks!
A lower-than-ideal-octane fuel will result in knock in carburetor-equipped engines that need more, and reduced power in fuel-injected engines with knock sensors.
A higher-than-needed-octane fuel will not produce any more power.
ST1100's are rated for regular, ST1300's are rated for premium. It's primarily based on the compression ratio.
Yes. I found out that my '96 Nighthawk 750 runs just as well on regular after using premium for several years.I use premium in my ST1100, I could be using regular all this time?
More goes in to the decision of what octane level fuel is required than engine compression. The ignition mapping on the FJR may use less advance under identical conditions, or it may retard the timing more than the ST does when the knock sensors detect something or both. It may run richer/leaner at the same amount of advance under otherwise identical conditions, etc., etc., etc.. In short- can't make a straight comparison based on compression rartios alone.ST1300 10.8:1 compression. FJR1300 10.8:1 compression. Honda manual says run premium gas. Yamaha manual says run regular gas. Supposedly Yamaha has more horsepower.
