Power Outlets
Ohio
Just got an ST 1300 and noticed these (2) accessory ports. Question, where do I find a male plug to fit? Thanks.
Columbus, OH
2003 ST1300A
Those look like standard PowerLets. You'd generally use them for heated gear, though the plugs can be used for electrical accessory connections. There are USB adapters for them.
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
Cords and adapters are available from many sources.
As we can't see under the covers, they could be 12v DC (think old cigarette lighters in cars, unless you're younger than 30), but more likely the DIN as mentioned. Some call these "BMW style", as they are popular on many of those machines, but John Deere tractors use the same plug.
But yeah, a picture of the innards would help to remove doubt.
Mesa, AZ
VFR750F, ST1300
First, you should inspect/trace to find where it’s getting power and what size fuse protects that circuit.
You can get all sorts of accessories for that. Very useful one is USB power outlets to charge phone and voltmeter to keep an eye on battery and charging system.
Amazon - Voltmeter + USB charger
Those powerlet outlets are manufactured to higher tolerances than cigarette lighter ports. Depending on who makes them (I'm sure there are good ones such as Powerlet, and not so good ones, if they are unbranded) I would expect they both handle similar currents. You will be fine as long as your fuse is rated the same as the Powerlet or lower.
Ohio
It’s about half the diameter of a standard cigarette lighter plug. Like nothing I’ve ever seen before. Thanks.
Ohio
The problem is I need to find the male connector that plugs into it. These are part of Honda‘s top trim level on these bikes I am told.
STRider
Oregon
2012 ST1300A
50
Great customer service from the resurrected Powerlet company too by the way. Another member here gave me the outlet, bracket and leads from the sockets, but not the wiring harness referenced in the installation instructions linked by @Hound
I wrote to them asking if I could buy just the connector and terminals so I could incorporate into my electrical system.
He asked for an address and sent me the entire harness, free of charge.
Please support them if you can!
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
<SNIP>
Up until the new BMW, it's the first thing I've added to every bike since the 80s.
This dumb GSA came with 2 of 'em already installed.
Powerlet...Hella...DIN 12V... or see ISO 4165. Amazon for example is full of plugs, sockets and adapters; 'Hella' or 'DIN 12V' seem to be the most useful search terms.
This ^. Knocked it out of the park. It's a DIN/ISO 4165 plug and as mentioned it's commonly branded as Hella Powerlet and also BMW among the more well known names.
Unfortunately you were told wrong. That's a third party kit of DIN plugs and not factory ordnance.
You finally found a source but you were given one early on:
