Hi Everyone:
This job is tough. Be prepared to spend at least an hour on your side, attempting to remove the CSC from a very confined space. I wanted to suggest a few tools that will make the job just a little bit easier.
This maintenance task is very rewarding, especially if you have been putting the CSC replacement off for months like I did. Shifting is markedly improved and definitely not as clunky.
- Long neck scraper: This happens to be a Crafterman scraper. I used this, to very carefully remove the brunt of the gasket material.
- Pernatex Gasket Remover: Removes traces of gasket material left behind, during the scraping process.
- 12mm Wratcheting Flex-Head Wrench: Removes/installs banjo nut after it has been broken loose.
- 12mm clawfoot flarenut wrench: This is to be used with a 6 inch 3/8 socket extention and a flex-head 3/8 drive 10 inch socket wrench. This was used to break the banjo nut free and then to tighten it back up again. If you are still confused about this tool (the clawfoot). just youtube it - it should start to make sense pretty quickly.
- 6 inch wratchet wrench with 1/4 inch drive: This was used to pop the CSC bolts off and proved to be very efficient. 72 teeth allowed swinging the wrench side to side to get the bolts off without much trouble.
- Long surgical foreceps (Harbor Freight): This was used to slide the new crush washers between the banjo nuts.
- Small prybar to break the CSC from the case. Again, you need to be gentle with this tool - you can damage the engine and or the CSC if you start cranking on this thing.
- Vulcanized gloves with knuckle protection. The moment you visualize where your hands will be spending the next hour or two, you will want a pair of these.
- A piece of stcrap 2x4: any amount of additional clearance helps with this job. You want to roll your front tire onto the 2x4, then lean the bike on it's kickstand.
