Article [11] ST1100 - Fuse Panel Installation
Seattle area
2016 FJR1300ES
265
Auxilary Fuse Panel Installation
(9/13/2001)
attachment.php
Auxiliary fuse panel velcroed to battery. Note the two in-line fuse connected to the positive battery lead. The yellow fuse goes straight into the flex tube and to the un-switched panel mounted on the air filter. The other fuse connects to the 'PILCO' relay and on to the auxiliary fuse panel. The relay is driven off the cooling fan circuit.
attachment.php
3/8" flex tube follows the frame tube all the way to the area above the head light.
attachment.php
The Datel volt meter is wired through the switch show and on to the unswitched power of the clock. This circuit was used because it didn't have the 1/2 volt drop normally found in circuits that run through the ignition switch. This was I can see the voltage drop before and after the headlights come on. The two upper BMW outlets are switched, the 3rd one is unswitched for easier battery charging.
attachment.php
Ram GPS mount and miscellaneous wiring.
attachment.php
The left box is my mp3 player adapter. The center box contains the GPS power converter. My Kriss headlight modulator is on the right.
attachment.php
The MP3 and GPS leads are run through the existing openings in the cover piece.
attachment.php
All buttoned up!
Re: ST1100 Fuse Panel Installation
What fuse panel is that, and where did you get it? I have a similar looking one, but it's too thick to fit in that location. Does yours use the standard or mini blade fuses?
Thanks,
Bob
Thanks,
Bob
Bob,
I just bought an identical unit to the one Adam used from NAPA. It was under $10.
I too have installed the Centech fuse panel on my 01ST1100 and another on my 00 KLR650. The KLR650 one has survived and I've never had to retighten or do anything to it. Takes a licking and keeps on ticking.
I found this helpful doing mine.
