- Joined
- Mar 18, 2006
- Messages
- 2,867
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Oh dear. I'll adjust my nose rating. Mine is now medium sized.
Great! One more wire to add to my helmet. Good thing I'm not a moto vlogger!Just come across this.
Upt.
Woosh! You're not kidding!Expensive and does it work?
Yes Ryan, two years back I deformed mine by thousands of miles in the sun with the visor up. I did not try to reform it as retailer sent me two after I bought one. Seems taking it out for the longest days of the year is a good idea. I left it out this year May, June, July, August. Seeing how heat was probably the main culprit, heat gun may not help.I bought the Shoei GT-Air 2 helmet that came with the Pinlock insert just over a year ago. I rode about 3 times in cool weather without it, and I quickly realized the benefits of installing it. Rather than pull it out in warmer weather I left it in (mostly because I didn't want to destroy it in storage, and I was worried about deforming the seal). But, I think I inadvertently cooked it in the Texas heat. Has anyone experienced a distortion in which the bottom of the Pinlock lifts off/folds away from the visor and creates a ~1/16" gap? I suspect the root cause of this was riding up to 30mph with the visor up. This allowed air pressure to contact that lower seal.
Any tricks to fix this (maybe a heat gun, or??). It isn't too noticeable at the moment, but riding to work in the rain I had some water drops get between the Pinlock and the visor which was quite annoying.
As always, your advice is very much appreciated!
Ryan
Under the water, I've been known to use that personal technique.Back to the fogging problem without using the pinlock, I know this sounds weird unless you spend any time under water diving. But I have used spit on my visor and had good results restricting fogging.
The little posts that hold the pinlock screen can be turned which affects how the it fits to the screen, did you try adjusting them?GF has a Schubert C3 and had to remove her's, it leaked thus actually collected water between the screens,
Of course I'm aware that those are cranks...The little posts that hold the pinlock screen can be turned which affects how the it fits to the screen, did you try adjusting them?
