Perplexing Front Brakes
....the seal......help retract the piston ......
This guy at about 3:30 gives a good idea of what retraction should look like.
On the other hand.....1 1/2 turn on the rear is about all I've had for close to 20 years on my 1300 and the mileage has been right along the Honda specs, same as what many others have documented.
And there you have it, one and a half turns on the rear wheel after 20 years, and gets the mileage in the stats…
I sent oilspot a video of my rear wheel spinning 3 plus turns with one push, and I’m getting 57-58 mpg.
I guess some folks just don’t settle for average, when it can be improved upon :rofl1:
I’ll try and call you tomorrow and we will continue trying to solve this for you.
Hopefully, I have resolved most of my brake issue.
Igofar provided tons of support and suggestions. My brakes were completely void of air (the #1 suggestion from Honda manual). The rear pedal was so firm, I had to readjust my brake light switch!!!
Okay, I kept you waiting long enough! After exhausting the easy stuff, I pulled the pistons from the calipers. The right front was a bit corroded and had some dirt in the seals. I pull the other six pistons and was relieved none were like the R front. (See pictures).
Then I had to bleed (and bleed again). Now my brakes don’t drag!
I still have some tuning and tweaking before I replace the Tupperware, but I think the culprit was the cruddy piston(s).
I’ll update if I find anything else. Hopefully this will at least restore my fuel economy back to 48+. And eventually, I hope to exceed 50 mpg with further tutorial from Igofar (the white courtesy phone).
This is worth checking. At minimum pull the Piston seals out and clean the grooves. You could possibly replace all the Brake piston seals as well.
You mentioned cleaning the pistons, did you by any chance get cleaner or solvent on the rubber seals?
After taking the pistons out and cleaning the seals, I have a much better understanding of how they work now. Originally I extended the pistons about half way and cleaned them with a thin pieced of shop rag dipped in brake fluid. I think I did a decent job of cleaning, but I found a small rough spot when the pistons were completely out of the caliper. So the "shoelace" cleaning method did work, but unfortunately wasn't going to address that rough area. I had to repolish that spot to ensure if was perfectly smooth - while being careful not to damage the anodized surface too much.
Did you get this sorted in the end?
i have a very identical problem where my front left caliper is binding, but runs free without pads. And because it’s that one it’s applying the rear slightly while riding. Have replaced seals and pistons and still not running free - same as you front off ground clearly wheel is dragging. Starting to think the caliper isn’t sitting square as before I replaced the pads (OEM used) the previous set were clearly chamfered.
Cheers
Cheers
There are a few things to check.
1. The wheel is installed correctly - make sure that the two spacers are the right way round and on the correct sides.
Note that the photo is showing the axle as if viewed from the front. Brake lever on the left of the photo, clutch lever on the right of the photo.
2. Make sure that the axle has been tightened in the correct sequence:
  • Push axle bolt home. Hold the axle and tighten the axle bolt.
    If you don't have a large enough Hex driver, then temporarily tighten the left hand (clutch side) fork pinch bolts, tighten the axle to correct torque.
  • Slacken the left hand pinch bolts
  • Tighten the right hand (brake lever side) fork pinch bolts to correct torque.
  • Bounce the front forks a few times.
  • Check that the left hand (clutch side) fork is flush with the end of the axle. It should be. If only a little out of place then move the fork leg until it is flush. If it is a lot out of alignment, then find out why.
  • Tighten the left hand (clutch lever side) fork pinch bolts.
  • Make sure that you have at least 0.7mm clearance where the disc passes through the slot in the caliper bracket.
3. Check that the pad spring is inserted the correct way round. Check the the retaining tag is not bent. Make sure that the pads are fitted behinf that retaining tag - ie to the side closest to the centre of the wheel.
4. Make sure that you have not put in a white heat shield (that is supplied only with OEM rear pads) between the pad backing plate and the chrome anti-squeal plate.
5. Make sure that you are not trying to put rear pads in the front caliper, or non-OEM pads that are too thick in the front caliper.
6. Make sure that without the pads in place, you can push the claiper in towards the disc and pull it away from the disc - and that it stays where you moved it to (ie it doesn't return of its own accord. If you cannot, then there may be an issue with the two slider pins. They are awkward to get at since the hydraulic hose keeps the caliper and the bracket fastened together. But if it is difficult to move, then that is what needs to happen - and will no doubt be the subject of a follow up question from you !
Read this. Article [13] - ST1300 - Brake Maintenance - Avoiding the Pitfalls | ST1300 Articles | ST-Owners.com
The reason that items 1 and 2 are important is that the wheel and the brake disc are secured to the axle. The left caliper is secured to the fork. The two are fixed independently of each other. If you get one of them wrong then the pads will not be able to move away from the disc surface.
Forgot to reply to this…
thanks for that information, sat on the drive for a few hours…. Took the axle out, cleaned up gunk off, put back on - callipers off, put pads in while off and ensured all in and aligned. Put all back together….
I had the outer edge of the left fork (clutch side) confused, the cast outer edge ended up with part of the smc bracket rubbing the disc, so aligned to the ‘inner’ machined edge and this gives a clearance. Tightened everything back up, still slight not wanting to run free, but pads are new. And it’s far better than what it was previous.
Bike has passed MOT, and have been out for a few little runs and all appears to be working fine - no unwanted heat on discs and now rotates far better.
thanks all
now I just have to free up the idle adjuster
Renew / top up the rear pre load adjuster oil
cheers
I sure want to watch his video's, and follow his advice :rofl1:
I had trouble getting past the first few seconds of his video where he clamps down on the brake line with a pair of vice grips ;)
So the axle end is slightly recessed ? did you check the clearance between the disc and the caliper. Slide a clean feeler gauge along the top edge of the disk backwards towards the caliper until it passes through the bracket. You should be able to get a 0.7mm feeler gauge through on both sides of the disk.
Did you check the distance collars when you put the axle back ? It is very easy to get the left one the wring way round. Putting it back as it was isn't good enough if it was wrong before !
Did you perform the axle tightening sequence in exactly the order described ?
The reason for my concern is that if everything is as it should be then the axle end is in the correct place and the forks are holding the caliper in the correct position. Therefore there should be clearance for the disc to pass through the caliper when the axle end is flush. Ie if you put a steel rule across there is no gap between axle and fork leg.
If that is not the case then something isn't right.
If that gap is there when the axle end is flush, then maybe it wan't the disc catching that you heard, but the pad spring which was dislodged when you put the caliper and brake pads on.
I have tried to put the brake pads into the caliper and then put the caliper onto the fork leg and have never succeeded without knocking one of the pads out of its seat at the top end. This brings the pad spring into question. If the pads have moved then there is a good chance that the inner pad has ended up on the wrong side of the tag on the pad spring.
I'm speculating. But if the axle end isn't flush in order get the clearance, then something is wrong.
