This week in Michigan I got my 93 ST legal and have put on about 110 miles. Still working out the bugs.. MY question where should the temp gauge be when running on the road?? In the middle or a little left or right of center?? Today it was cool low 60's Riding around on the back roads all is well. Then I took off on the Highway and the temp gauge dropped to just above the second white mark. To me I have a stuck open thermostat. Where the picture shows. Also what is the temp that the thermostat opens for reference. 180, 190?? Second I was thinking I should change the fork oil. My Clymer manual I do not see about changing the oil. Just rebuild the forks. I have done older cycles. Can I change the oil like I am used to?? Pull the drain plug. Take the weight off the forks. Loosen the top clamp bolt, then take out the top plug. Add the proper amount of fork oil per side.. I see the side to side are different.. The plug is what I have circled. No leaks that I see, but maybe there is no oil..??
